Traction
um...normally the stiffer suspension is better it prevents wheel hop and what not. But traction, in general, comes from the tires not the suspension. However camber can play a big role. 0degrees camber (tires straight up and down) means the whole tire tread is directly on the ground while alot of these rice boys with 5" drops only have the inside edge of their tire on the ground..so 1/2 the contact patch.
So if you wanna drop the suspension make sure you get a camber kit for max traction.
liam
liam
The height of your car makes almost no difference whatsoever. The suspension factors that contribute to traction are the spring rate combination front to rear, and the rebound/dampening capability of your shocks.
BTW, you will certainly have traction problems after you turbo your car for awhile because your right foot is gonna have to get a lot smarter.
edit: the height of your car makes no difference, assuming camber remains the same!
[Modified by fsp31, 11:12 PM 2/25/2003]
will it be hard to gain traction if i turbo my car before i lower it?
What does lowering your car have to do with traction? Only reason you'd have any different traction from lowering your car was if you has stiffer springs (maybe more traction) or shitty camber(maybe less traction)
and as Shinzon from StarTrek Nemisis said "...don't be so vague"
From what some of the fast guys say in the Drag & Tech forums, you want your rear inner LCA pivot points to be equal to or lower than your front LCA inner pivot points for optimal launching.
Smarter than you
Whoa, wrong answer!! The height of the car is directly related to weight transfer. The lower the center of gravity the better....
but seriously, get a good suspension if u r gonna be racing a turbo car. stock suspension transfers wieght like crazy. but dont forget tires, I don't care how much power u make tires put it to the ground and are the most important mod on any car. at least get some springs/shocks and good tires.
[Modified by DIRep, 5:25 PM 2/25/2003]
just get some bling bling airbags or hydros yo and drop that shiznit so you get traction like a **** yo.
j/k depending on your budget is gonna be the factor here, you can get some $600 setups or $2000.
yea i've already got some slips with kuhmo ecsta supra 712 tires and i was planning on getting an eibach prokit with kyb agx shocks.
[Modified by IMPULSE B18C-T, 10:34 AM 2/26/2003]
you don't need a camber kit for eibach prokit springs...**** you can't even tell they lower the car at all...i guess unless you have some 17 or 18 inch wheels!
Matt, you are why murder should be legalized. You have been asking turbo questions for about 6 months now. Here you go...
FWD + Turbo = NO TRACTION
Lowering your car WILL NOT help much at all with traction. Only sticky tires, stiffer shocks in the back, stiffer motor mounts (to get rid of wheel hop), and a LSD will help you hook up. You shouldn't have too many problems though just because you would only be pushing like 2-3 psi...
redDAinteg
Jan 27, 2007 11:32 AM
supratt
Jan 21, 2002 06:33 PM
