toda Cs on a boosted del sol.
Old Jun 24, 2006 | 05:36 AM
ah789454's Avatar
Default toda Cs on a boosted del sol.
i did a bit of research for my turbo civic. i didnt know if i should get a turbo cam or a NA cam. i found a workshop here in melbourne australia that put the toda Cs on their boosted b16a and got 534hp/400kw
i hope this help gives ppl an inside to what na cams can do on a turbo car
Old Jun 24, 2006 | 10:22 AM
non-VTEC's Avatar
Default Re: toda Cs on a boosted del sol. (ah789454)
wow thats awesome...........how much boost?
Old Jun 24, 2006 | 12:42 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
most dynos i have been around give a way higher number when you scale it to wheel speed instead of engine rpm. for example when i used to use a mustang dyni, my n/a civid would show well over 350whp@ XXXMPH
but 187@XXXXRPM
something to do with the trannies multiplication of power
Old Jun 24, 2006 | 02:11 PM
ah789454's Avatar
Default Re: (BrokeAssWhiteboy)
its running 25psi i think.
thats with the old set up ,i believe theyre up to 450kw now
Old Jun 24, 2006 | 07:02 PM
Tony the Tiger's Avatar
Pretty fascinating... I would actually be way more interested in the cam gear settings though...
I am not much of a fan of aggressive NA cams in a boosted setup.. Last thing I'd want to worry about is problems from most built NA setups -- timing belt snapping, valve springs binding, valve float, worn retainers. Now add our typical boost problems onto the list...haha It's a mobile time bomb
Old Jun 24, 2006 | 07:33 PM
mrbsponge's Avatar
this is an interesting subject because we have been looking at a few different cam profiles of "turbo cams" and SOME of them are exactly a copy of some N/A cams..............I believe a very popular turbo cam was Extremely close to a set of buddy club 3s
Old Jul 6, 2006 | 12:55 PM
ah789454's Avatar
Default Re: (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Pretty fascinating... I would actually be way more interested in the cam gear settings though...
I am not much of a fan of aggressive NA cams in a boosted setup.. Last thing I'd want to worry about is problems from most built NA setups -- timing belt snapping, valve springs binding, valve float, worn retainers. Now add our typical boost problems onto the list...haha It's a mobile time bomb </TD></TR></TABLE>
yeh i thought it would be a time bomb just waitn for explode.
but the car has been a daily driver for 3 years now.
hey tony im building my set up similar to yours. once i seen your video of the high comp turbo i was hooked
Old Jul 6, 2006 | 01:39 PM
quicksilver1689's Avatar
i ♥ snails
What happens with high boost applications and excessive overlap? wouldnt that bleed off boost on the top end?
Old Jul 6, 2006 | 01:49 PM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">I am not much of a fan of aggressive NA cams in a boosted setup.. Last thing I'd want to worry about is problems from most built NA setups -- timing belt snapping, valve springs binding, valve float, worn retainers. Now add our typical boost problems onto the list...haha It's a mobile time bomb </TD></TR></TABLE>
sounds like we're gonna have more terrorist. someone call president bush! lol
Old Jul 6, 2006 | 02:14 PM
BB6-213's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like we're gonna have more terrorist. someone call president bush! lol</TD></TR></TABLE>
nah, don't worry about it...the only oil that guy has is the 5 quarts in his motor.
Old Jul 6, 2006 | 02:49 PM
rextec's Avatar
Default Re: (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">
nah, don't worry about it...the only oil that guy has is the 5 quarts in his motor.</TD></TR></TABLE>
hhahahah lmao, so true!!!!
lindseyhunt1090
Apr 23, 2016 11:06 PM
Tarzan
Dec 21, 2010 12:28 AM
Seymour222
Honda S2000
Aug 23, 2006 11:23 AM
EGkid
Jan 4, 2005 07:04 PM
SpeedMonkeyRacing
Oct 21, 2001 02:04 PM
