TiAL WG gasket blown after 1 week @ 7psi! WTF!?!
I finally hit 1000k mile on the newly built bottom end so I went out last night and gave it a few runs and the gasket on my brand new WG blew a hole in itself! Are TiAL WG Gaskets just weak or did I do somthing wrong? I was only boosting 7psi !!
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (Diego Boost)
Mine went bad after about 20 miles on 8psi, so i guess it happens.. I removed the wastegate about 3 times without changing it tho if that helps...
use a deltagate gasket, the tial ones suck!
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (DIRep)
dont use TIAL gaskets. get the drag one with the fire ring.
krazy |
Cool, thanks Chris... anyone wanna sell me one? lol
My Tial gasket did not take long to blow. I ended up just taking the gasket out and not using one at all. I haven't had any problems since.
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (dragnGSR)
They sell the "fire ring" deltagate gaskets at http://www.roadraceengineering.com
Stock up on gaskets/flanges, they give 20% discount for ordering 5 or more of anything in that section. |
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (Hatchblack)
I haven't ran a wastegate gasket in over 14mos and 35,000 miles. I haven't had 1 problem.
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (hybrid901)
Thanks guys. I'll run my old Deltagate gasket until I can get somthing better. https://honda-tech.com/forums/images/smilies/emthup.gif
I usually run the wastegate with no gaskets, and have found no leaks or problems in doing so. Since upgrading to the Tial 40mm, they dont use gaskets because of the machine surfaces so I wont be running gaskets again. I will be running the turbonetics fire ring gasket on my GF's turbo d-series. Road race engineering is a great company, its where i buy all my flanges, gaskets and piping.
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (boosted hybrid)
which gasket?
you talking about the donut /ring one? or just the plain old flange type gasket? |
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (SiRkid)
I bought a turbonetics gasket with the metal ring in the center, I too blew my tial gasket within 2 weeks at 12psi.
I got the turbonetics one ($10) and ran 15 psi and havent blown it since. I cracked a sleeve before the gasket went out. Thats how strong they are j/k https://honda-tech.com/forums/images...es/emsmile.gif |
which gasket? you talking about the donut /ring one? or just the plain old flange type gasket? |
No gasket on mine and no problems....I blew the one I had before so I did away with it...seems to me without is probably the easiest way, just make sure nothing starts to rust then you may run into some problems
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (Elite Hatch)
Gotta Live By the 3 B's -> Boost Beer Bitches running w/ out a gasket is fine on the wastegate, carbon build up will seal it anyways https://honda-tech.com/forums/images/smilies/emwink.gif |
Of course man...haha
They sell the "fire ring" deltagate gaskets at http://www.roadraceengineering.com Stock up on gaskets/flanges, they give 20% discount for ordering 5 or more of anything in that section. http://www.roadraceengineering.com/tial.htm |
This ia a part you can safely skim on. You don't really need to use a gasket for the wastegate. Just torque it down.
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (ben@importparts.com)
This ia a part you can safely skim on. You don't really need to use a gasket for the wastegate. Just torque it down. |
Re: TiAL WG gasket blown after 1 week @ 7psi! WTF!?! (Mase)
mine went too but the bolt on the back where the one vac/boost line goes was hitting the valve cover so i ground the bolt down and used the gasket from my old deltagate and never had a problem since
