Tial wastegate spring
Old Feb 20, 2009 | 10:17 PM
Fastjato33's Avatar
Default Tial wastegate spring
I was wondering what lb spring comes in a new 38mm tial wg? the older style and I can't get mine to go over 20psi
Old Feb 20, 2009 | 10:31 PM
TheShodan's Avatar
Moderator
Default Re: Tial wastegate spring
You'll need to compare the spring chart with the spring you have. It will require opening the wastegate. Remember, the spring can take up to 2.5 times the pressure rate of the spring used. Example. if you have a 10lb spring, X 2.5 = 25psi...
turbo-crx
Apr 1, 2009 11:42 AM
b18befhatch
Nov 22, 2005 08:15 PM
FlatTire
Apr 29, 2004 01:47 PM
