Tial Wastegate ???
I am in the process of prepping my stuff for the turbo install, and this tial wastegate came disassembled. Anyone have any instructions on how to put this thing together. Any help would be appreciated, thanks again.
hmm, if I am not mistaken, just put the spring back on in place and tighten the allen bolt just like you're tightning lug nuts....
do a little bit at a time per bolt...ubtil it's tight and do half a turn...
Ok, the spring and the wastegate are together, there is a round circular thing with a beveled edge, that goes on the bottom(right)spring, this is the actual end that connects to the manifold, the opening that is on the side just vents out into the air if you are not going to run a closed loop system right? Sorry, all my experience lies in internal wastegates, first external exp. but thanks again.
that round piece u are referring to goes in between the flange u got and the inlet of the wastegate... the hole on the side of the wg is for the air discharge
