Thoughts on APEXi Super AVC-R Boost Controller
Old Oct 13, 2003 | 10:12 AM
underpressure02's Avatar
Default Thoughts on APEXi Super AVC-R Boost Controller
I am looking to buy a boost controller for my car. I was going to go with the greddy Profec B spec II but I read a lot of posts of people saying they have problems with it. I had a turbosmart DSBC in my car that got stolen and never had a problem with it. So I am thinking of either the APEXi Super AVC-R Boost Controller or a turbosmart or turbo XS b/c of less things to brake/go wrong.
What are your thoughts on the APEXi Super AVC-R Boost Controller? Is anyone running them are you having any issues with it or is it dependable?
Old Oct 13, 2003 | 11:26 AM
VTC_CiViC's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (underpressure02)
I used it with my Civic, considering how bad the wastegate fluxed at higher boost levels I thought it did very well. I have a Profec B right now in my Teg but I'll probably go and get another AVC-R eventually. Datalogging boost is
Old Oct 22, 2003 | 06:53 AM
ttt
Old Oct 22, 2003 | 07:42 AM
boosted hybrid's Avatar
Just bought one for my hatch, going from my profec b to the AVCR. The profec wont hold boost stable on the high channel, even with playing with all the overboost/internal wastegate buttons. This is not a common problem, but something I have been dealing with. I have tuned with several AVCR's, they are dead consistent at holding boost if you set them up properly. The learning mode is a great feature, and boost comes on rock solid and is held solid.
Old Oct 27, 2003 | 11:43 AM
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (boosted hybrid)
any other thoughts
Old Oct 27, 2003 | 11:54 AM
phase12gsr's Avatar
I've never owned a Profec B, but boosted hybrid nailed the pros of the AVC-R straight on. People will complain about how hard it is to tune, but it is actually pretty simple.
Old Oct 27, 2003 | 12:00 PM
DC2R714's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (phase12gsr)
People overcomplicate the AVC-R. When looking at all the features it does look mind boggling, but once you figure out what really needs to be set its easy. Learning mode is great. It helps keep boost consistent and will adjust duty cycle. Running in the cold then warm weather your duty cycle will change and the AVC-R compensates for that. Definitely noticeable in the winter.
Basically set your boost, set duty cycle around 25-30% leaving some area higher or lower to put it in learning mode and go. Do a few pulls and check the duty cycle. It should be fixed accordingly. Make sure to monitor that you arent exceeding the target boost level or the learning mode won't set itself.
Old Oct 27, 2003 | 12:22 PM
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (DC2R714)
i can use this in conjunction with hondata or aem ems correct?
Old Oct 27, 2003 | 12:26 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">i can use this in conjunction with hondata or aem ems correct?</TD></TR></TABLE>
yup, sure can
Old Oct 27, 2003 | 12:27 PM
SEFIxCivic's Avatar
i've never owned one myself, but my friend who is good with electronics and a damn good mechanic had one on his car, and never got it working 100%. buyer beware if you have a past history of not being able to figure things out.
Old Oct 27, 2003 | 01:01 PM
VTC_CiViC's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (SEFI8LOxCivic)
I owned one and loved it, now I'm selling my Profec for another AVCR
Old Oct 27, 2003 | 01:51 PM
IMSTOCK's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (VTC_CiViC)
Are'nt you able to adjust your boost for every gear with the AVC-R?? If not what boost contollers allow you to do so??
Old Oct 27, 2003 | 02:13 PM
XES's Avatar
XES
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (IMSTOCK)
Yes, you can have gear dependant boost settings.
I've had the AVCR for over 3 years now and wouldn't trade it for anything else on the market. Boost is so stable in every gear. You won't be disappointed.
Old Oct 27, 2003 | 02:24 PM
spoolinlude's Avatar
I live under a rock
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (XES)
agreed
Old Oct 27, 2003 | 09:27 PM
E46M3CB's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (spoolinlude)
is the avcr any good with hondata?
Old Oct 27, 2003 | 09:30 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can have gear dependant boost settings.
I've had the AVCR for over 3 years now and wouldn't trade it for anything else on the market. Boost is so stable in every gear. You won't be disappointed.</TD></TR></TABLE>
Same here. Yes it works great with hondata.
Old Oct 27, 2003 | 09:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (B18CDB8)
looks like thats what im getting
Old Oct 27, 2003 | 10:19 PM
roydogg's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">looks like thats what im getting</TD></TR></TABLE>
I just ordered mines .
Old Oct 28, 2003 | 04:59 AM
B18bEK's Avatar
i want one
Old Oct 28, 2003 | 05:41 PM
IMSTOCK's Avatar
Default Re: Thoughts on APEXi Super AVC-R Boost Controller (roydogg)
Hey Roydogg, where did you order your AVC-R from, and for how much??
Old Oct 28, 2003 | 06:29 PM
He got it from here https://honda-tech.com/zerothread?id=646261 and beat me to it. I offered the guy a little less and the next thing I knew it was gone.
Good luck with it.
Old Oct 28, 2003 | 06:59 PM
InfamousDX's Avatar
AVC-R datalogs? Never knew that.
Old Oct 28, 2003 | 07:05 PM
espanol's Avatar
i've never had problems w/ any of the avcr's i installed.
Old Oct 28, 2003 | 08:04 PM
roydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">He got it from here https://honda-tech.com/zerothread?id=646261 and beat me to it. I offered the guy a little less and the next thing I knew it was gone.
Good luck with it. </TD></TR></TABLE>
There's one for sale in the FI classifieds. Be patient and you'll get one even cheaper . Or if I'm in desperate need of money I'll IM you .
Old Oct 29, 2003 | 05:39 AM
there was three for sale in the fi classifieds. Two used and the one you got. The one used one was missing a piece and sold for 230. The other one, I just do not feel confortable buying a used electronic piece.
