Synapse Ramhorn - AC + PS allowed
Old Jan 27, 2009 | 09:28 PM
Sohc52's Avatar
Default Synapse Ramhorn - AC + PS allowed
Any1 here running this on A B or D series?
Said to be able to clear AC + PS by Synapse Turbo.
Would need some ppl who have experiences with this Ramhorn as i am interested to fit this in my SOHC built with the BW S256 and a 3" DP.
Pls chime in guys!
Old Jan 27, 2009 | 09:46 PM
boosted ej8's Avatar
Default Re: Synapse Ramhorn - AC + PS allowed
you might not clear it with a 3 inch dp
if you went 2.5 its possible
really depends on what clearance you have once its in your car
And I'm unfamiliar with the BW sizes, what is the s256 equivalent to
Old Jan 28, 2009 | 12:18 AM
Sohc52's Avatar
Gt3071R. Was thinking of having it position like this:
Compressor housing next to the PS side while the turbine housing on the gearbox side.
As for Radiator fan will be relocated to the front.
I will be hoping to run this kind of setup for the manifold.
Full length radiator 2" aluminum
Condensor relocated to in betwen the Rad and IC.
hoping to be able to run 3 fans. or at least 2.
2 fans facing away the car while 1 on the condensor side facing the manifold.
have seen some locals did it. but then they are using minirams which are locally customized.
g2turbo
Nov 22, 2009 03:57 PM
Black R
Jul 16, 2009 06:05 PM
nick91civicsi
Oct 4, 2007 02:29 PM
VIS250P
Jan 4, 2007 02:01 PM
NumberB
Jun 10, 2006 02:05 AM
