Switching injectors from 460cc to 440cc
Old Nov 29, 2013 | 04:51 PM
johnsc2235's Avatar
Default Switching injectors from 460cc to 440cc
I was running 460cc injectors but one got plugged up so I got a good deal on some rc440 injectors.. Am I going to have to get a re tune or will it not make much of a difference?? Does it matter what the fuel pressure reg is set on?
Old Nov 29, 2013 | 08:16 PM
Turbo-LS's Avatar
Default Re: Switching injectors from 460cc to 440cc
it will need to be cleaned up unless you were on the rich side. If you have a wideband in the car you can monitor the a/f ratios youll know if it needs more fuel or not.
Old Nov 30, 2013 | 12:23 PM
Muckman's Avatar
Moderator in Chief
Set fuel pressure to the same, remove 4-5% of fuel across the board, then monitor AFR.
Old Nov 30, 2013 | 01:14 PM
Turbo-LS's Avatar
He's going down in size not up.
Old Nov 30, 2013 | 04:34 PM
Muckman's Avatar
Moderator in Chief
Then add 4-5% lol
rdeezy78
Nov 24, 2008 05:15 PM
Haleiwa-Brando
Sep 3, 2005 12:31 PM
ATS*Mark
Aug 7, 2004 10:12 AM
Dorikamu
Oct 14, 2002 08:12 PM
Malice
Jun 7, 2002 11:31 AM
