Swapping pistions and rods?!?
Sup all,
Did a compression test on my plant and its not well. cyl #4 is at 75!!
I pulled my pistons today and found the the ring land is cracked on #4 and #3. So I'm considering slapping in a set up forged pistons and rods at the moment. My question is, If I were to stick with stock bore and change my pistons, rods, connecting rod bearings, main bearings, and do slight hone on the cylinder walls, would this be sufficient?? would I have to rebalance my bottom end? I know I should do a complete build(ie machine shop) however I need to get my car on the road as soon as possible. Any info would help!!
Modified by Chillinit at 12:21 PM 5/25/2004
I pulled my pistons today and found the the ring land is cracked on #4 and #3. So I'm considering slapping in a set up forged pistons and rods at the moment. My question is, If I were to stick with stock bore and change my pistons, rods, connecting rod bearings, main bearings, and do slight hone on the cylinder walls, would this be sufficient?? would I have to rebalance my bottom end? I know I should do a complete build(ie machine shop) however I need to get my car on the road as soon as possible. Any info would help!! Modified by Chillinit at 12:21 PM 5/25/2004
yea just run a hone through it. i deally you want to take it to a machine shop and have them hone it to the piston specs. but just check what the clearances are and you might be okay.
Landon
Landon
Needs rebalenced.
Big rods, different pistons on stock crank ? The "bob weight" is different meaning that the old rotating ***. was lighter basiclly.
"You can drive with your feet, but that don't make it a good f**king idea !!!"-Chris Rock
That's IMO. I'm the honda guy with low compression turbo, what do it know ?
kpjo4
Mar 11, 2010 07:56 PM
for the responses....anyone else??
