Surging idle on h22 turbo
Old Jul 15, 2004 | 12:51 PM
killa_lude's Avatar
Default Surging idle on h22 turbo
my idle surges from 1200 to 1500rpm when i start it up, (either when the motor is hot or cold) and im 98% sure its not a vacuum leak. what the hell else could it be? i drilled a idle air hole in my golden eagle intake mani, could that be the problem? before the car wouldnt idle unless there was a vacuum leak. and i noticed that there wasnt a hole on the mani to fit the idle hole on my inline4 tb. so after i did that, i plugged the vacuum leak that i left open before (so the motor wouldnt kill out) and now the idle surges....any ideas?
Old Jul 15, 2004 | 03:13 PM
killa_lude's Avatar
Default Re: Surging idle on h22 turbo (killa_lude)
bump
Old Jul 15, 2004 | 08:13 PM
killa_lude's Avatar
ttt
Old Jul 15, 2004 | 08:33 PM
solowerks's Avatar
just curious, are you running afc hack? I had a idle surge, and instead of running -40 at idle i tuned it to -33 to prevent the idle surge. It has something to do with the voltage to the map sensor I believe while running the hack
Old Jul 15, 2004 | 09:56 PM
killa_lude's Avatar
Default Re: (solowerks)
no afc hack...
Old Jul 16, 2004 | 09:22 AM
killa_lude's Avatar
Default Re: (killa_lude)
ttt.
Old Jul 16, 2004 | 06:50 PM
ntegls's Avatar
to check for vacuum leaks spray hoses and manifold w/ brake clean, if it starts to idle fine where ever you spray leak is there, also could be iac valve
Old Jul 16, 2004 | 10:28 PM
TurblowR's Avatar
Default Re: (ntegls)
mine does that when i start the car and let it warm up, but it only happens when i start the car for the first time in the morning. it idles fine after that all throughout the day. i always thought of it as normal.
Old Jul 17, 2004 | 12:28 AM
The-LS's Avatar
when did this start? did if occur after some work was done or out of the blue?
Old Jul 17, 2004 | 08:37 AM
killa_lude's Avatar
Default Re: Surging idle on h22 turbo (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">when did this start? did if occur after some work was done or out of the blue?</TD></TR></TABLE>
right after i plugged the egr on the block...then it started to idle like that. but before i had a vacuum leak....so i plugged both at the same time. and it started to idle all gay.
cfoland
Feb 19, 2011 08:33 PM
cfoland
Feb 18, 2011 07:57 PM
killa_lude
Jul 17, 2004 08:39 AM
blackZC (W)
Jun 21, 2004 05:58 AM
tinkerbell
Jan 28, 2002 06:12 PM
