stronger oil pump?
Old Jun 12, 2002 | 09:31 AM
austrian type-R's Avatar
Default stronger oil pump?
Anyone have a street setup with a stronger oil pump like Spoon? I mean the oil pump has more work on turbo cars to feed the oil lines and even more with some oil coolers. Someone know the press drop when using oilcoolers and turbo.
Old Jun 12, 2002 | 11:15 AM
BoOsTeD_eK's Avatar
Default Re: stronger oil pump? (austrian type-R)
well I dont think there should be that much of a pressure drop in your oil..cuz when you add oil lines and coolers and all that good stuff...you are no longer using the same amount of oil..so the extra space created by the added lines and stuff is filled by more oil...a higher flowing pump wouldnt hurt...my friend uses the toda gear....no complaints.
eag36
Mar 30, 2005 05:40 PM
sk8rmike
Oct 8, 2003 08:41 PM
untuned
Nov 1, 2002 07:43 AM
