Stock bearings ???
Old Feb 8, 2005 | 11:06 AM
golangti's Avatar
Default Stock bearings ???
Im building a B16 turbo and wanted to know if I should use the stock main and rod bearings, and where is the best place to get them
Old Feb 8, 2005 | 11:37 AM
RyanEJ8's Avatar
Default Re: Stock bearings ??? (golangti)
Stock are good. I personally like ACL.
Old Feb 8, 2005 | 11:44 AM
tgreaves's Avatar
I use acl bearings also.. Remember with any bearing you need to be inbetween a bearing range..
You will see some people here that mic their bearing with a set of verniers that they bough from the local parts store and think that what they are doing is accurate...hehehe funny.. Your not going to be able to dial in exactly the tolarances that you want like that.. If would just get a set of acl bearing and plastigauge everything to make sure you within the honda tolarances..... Also talk to Earl about this, he will be able to get you ACL bearings and help you out..
Old Feb 8, 2005 | 11:46 AM
g2turbo's Avatar
Default Re: Stock bearings ??? (tgreaves)
I opted the ACL route as well. Much easier than getting bearings from honda as well as being cheaper. I got mine through EARL
Old Dec 20, 2007 | 09:57 AM
hondapimpin420's Avatar
Default Re: Stock bearings ??? (g2turbo)
who is earl and how i get ahold of him
Old Dec 20, 2007 | 10:02 AM
carzntune's Avatar
Default Re: Stock bearings ??? (hondapimpin420)
I assume Earl Laskey, who has since passed away from the time that post was made.
R.I.P.
Rasmusm
Jun 17, 2013 10:37 AM
tgreaves
Feb 2, 2004 01:17 PM
9seccivicsi
Jan 19, 2004 05:30 PM
JDMCRX
Oct 27, 2003 08:35 AM
jdmR
Aug 12, 2002 11:00 AM
