Stiffness difference between intake and exhaust valvesprings?
Old Dec 9, 2001 | 02:34 PM
austrian type-R's Avatar
Default Stiffness difference between intake and exhaust valvesprings?
Is there a diff in the stiffness of an intake and an exhaust valve spring from crower? I have heard the stock valve springs of an ITR are different, but I couldīnt find any colored marks on the springs, either on the ITRīs and on the Crower.
Old Dec 9, 2001 | 07:44 PM
Default Re: Stiffness difference between intake and exhaust valvesprings? (austrian ITR)
comonīguys! nobody know it?
Old Dec 10, 2001 | 05:33 AM
rtype11's Avatar
I can only tell you what I did with mine, if you wish to go over your stock limit you must increase the seat pressure, spring rate and if using a big cam make sure that the spring can handle the coil bind, basically increase the intake and exhaust the same rate, intake valves apply abt 20PSI more pressure throughout. there are a couple of springs out there that will grind your cam and ruin your valve seats so watch out, increase your spring pressure no more than about 40PSI.
Old Dec 10, 2001 | 05:58 AM
Default Re: Stiffness difference between intake and exhaust valvesprings? (rtype11)
Thanks!
Hondaruss
Dec 18, 2010 09:17 PM
jdmb18c
Apr 4, 2005 03:30 PM
Aeka GSR
Oct 27, 2003 10:39 AM
joshwhe
Jan 29, 2003 12:33 PM
TypeR0207
Sep 6, 2001 01:12 PM
