SSAC turbos........
Ok we all know about the horror post about the glue... BUT... ive talked to 2 recent people that run them for more then a year now and have had no problems. One ran the t3t4 and one ran the t70... Anyone else on here run them or had any other issues?
Waste of $$$
. /thread |
Re: (Danny_EJ)
I would like an update on some of the people running them as well.
It seems like we had a bunch of these threads popping up about a year ago about how the SSautochrome turbos are working fine. And a bunch of people were buying them. I would like to hear from people that have been running them over the past year. Is it possible that they are still holding up?? |
1+ year with no issues at all. 12psi daily https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">1+ year with no issues at all. 12psi daily https://honda-tech.com/forums/images/smilies/emthup.gif</TD></TR></TABLE>
Which turbo? Which vendor? |
Re: (EJ1 wilcox)
t3 .42/.48
straight from ssauto, XSpower t3 https://honda-tech.com/forums/images...s/emsmilep.gif the trick to getting them to last a long time is running an oil restrictor https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">t3 .42/.48
straight from ssauto, XSpower t3 https://honda-tech.com/forums/images...s/emsmilep.gif the trick to getting them to last a long time is running an oil restrictor https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (EJ1 wilcox)
just got mine on last saturday and its awsome!! highly reccomended. if you do "search" on the ssac shit,. its all 2 years back, im sure by now they corrected theier problems.
Re: (richieTN)
1 year on 3 diff setup. still working https://honda-tech.com/forums/images/smilies/emthup.gif
ps. wreck my car with it on there. |
been rinning one the last 9 months. it even survived sucking in one of my old a/c plugs that was just hanging....digested half of it and still no problems
i have been running 15psi on mine ever since i put it on, and i poorly maintained it. still no shaft play or nothing, the only reason i took it off was i bought a bb garrett |
Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy »</TD></TR><TR><TD CLASS="quote">it even survived sucking in one of my old a/c plugs that was just hanging....digested half of it and still no problems</TD></TR></TABLE>rofl, nice! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (ryan89crx)
One .42 .48 T3 5K miles on it working great,one "super T70" not much mileage yet but working great one T25 I used for 2500 miles and sold to someone else and last I heard holding up still and one T3/T4 currently has over 15K miles and has lots of shaft play getting near the end of its life but still building boost.All XS Power directly from SSautochrome I only get knock stuff directly from them and so far have had zero problems with any parts inluding lots intercoolers[really like these],tons of BOV's including the 50mm Tial knock off https://honda-tech.com/forums/images/smilies/emthup.gif,wastegates[double check assembly].I also order my Vband's from them as there only $30-40 https://honda-tech.com/forums/images/smilies/emthup.gif I used one mani once but it broke shortly after i sold it as they are complete %100 garbage https://honda-tech.com/forums/images...s/emthdown.gif I know lots of other people using them with very little if any problems but I hear alot of stories of them packing it in so who knows.I will continue to use them as the money I saved i used to buy slicks,traction bars a wideband etc https://honda-tech.com/forums/images/smilies/emthup.gif
we have a customer with the xs power kit
at 5.5lbs ls stock xs power kit 200whp on a dynojet.... it s been a month i wonder how long it will last? |
Mine is still going after 1.5 years, 6psi daily driven. If Jeff Evans from Evans-tunign supports the stuff why doesnt everyone?
i have a kit and have yet to have it tuned. my only problem so far is my snail doesn't have the vacuum fitting on it!
Re: SSAC turbos........ (Black00em1)
I bought one almost two years ago without doing any research https://honda-tech.com/forums/images...s/emsmilep.gif However I decided to use it anyway as I had already spent too much going to the dark side....
It has been in the car since Feb-05 and has been problem free. I expected it to die a long time ago and then replace it with a Garret, but it just won't die! I wouldn't recommend one as I had all kinds of problems with their manifold https://honda-tech.com/forums/images/smilies/emsad.gif but the one I have has been a good unit. Go figure! |
Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo »</TD></TR><TR><TD CLASS="quote">Mine is still going after 1.5 years, 6psi daily driven. If Jeff Evans from Evans-tunign supports the stuff why doesnt everyone?</TD></TR></TABLE>
Does he have the final say these days??? |
running one of the 57 trims for 2 years 16 psi 420hp on an lsvtec piston rods 9to1 comp no problem 25k miles has some shaft play but using it until it blows https://honda-tech.com/forums/images/smilies/emwink.gif
Re: (ryan89crx)
the trick to getting them to last a long time is running an oil restrictor https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE> Need some serious info on this....I'm planning on buying on of those soon for my GSR/CRX. |
Re: (1990hondaHF)
Bought mine used with 10k miles on it. No shaft play, BOV, WG, manifold, IC, all holding up fine. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (93CX)
Now im debating, T3T4 57 Trim 8-10psi on my stock b16a or... building a b18b with a b16 or gsr head (lsvtec) with rods/pistons 8:5:1 or 9:1 compression and running there t-70 with a top mount manifold insted of the ram horn im planning now..
Either way i plan on really thinking it over as i have 4 months to decide how i want to plan this out. Either way im ordering my intercooler, piping, bov from S-FAB and from there ill plan the manifold,down pipe, turbo and motor setup. Brad (sfab) ran the t70 on a 2.0l ls and went 11.0 said from 5k on it was nuts and im considering going this road. Or ill leave the car as a daily and run there t3t4 57 trim on a ram horn manifold and just be happy. so many choices... https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (1990hondaHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF »</TD></TR><TR><TD CLASS="quote">Need some serious info on this....I'm planning on buying on of those soon for my GSR/CRX.</TD></TR></TABLE>search ebay for "Function7" im using their t3 oil inlet flange/restrictor https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (B18C Turbo)
Are we supposed to give a flying apeshit about which parts are approved by Jeff Evans?? https://honda-tech.com/forums/images...s/emthdown.gif |
Re: (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee »</TD></TR><TR><TD CLASS="quote">
Are we supposed to give a flying apeshit about which parts are approved by Jeff Evans?? https://honda-tech.com/forums/images...s/emthdown.gif </TD></TR></TABLE> Yes.This is Honda Tech remember where nut swinging was invented. |
Re: (pgmatt)
600miles on my xs power/ssac turbo with restricter and intercooler with no problems whats so ever.. https://honda-tech.com/forums/images/smilies/emthup.gif
| All times are GMT -8. The time now is 11:29 PM. |
