SR20DET, help on turbo pick
Old Aug 1, 2003 | 06:06 PM
turboex's Avatar
Default SR20DET, help on turbo pick
Ok guys i need a bit of help on picking my turbo, I tried the nissan sites but there all about little turbos and drifting. I had an hks2030 it was ok but not much power, just a bit bigger than stock setup. As of now i am running a stock setup with fuel pump, FMIC, bov and and i hit a 8.6 on stock boost in the 8th so its not to bad. ill be getting a power FC and 750 injectors very soon, i have just gotten my top mount manifold and wastegate is on the way, but i am yet to pick a turbo. I have been looking at the SC61 im shooting for 425hp or in that area. But i just dont want to over kill the setup with a turbo thats to big. This is a car i drive to wrok everyday, but even witht he wastegate open and zero psi of boost the car is fine to drive so im not worried to much about spool time. any ideas would be great, i have my sorces for the turbo if tis precision, so you dont have to recomend ART. As i will be buying from him anyways. Thanks for the help guys, please dont hate as i now have a nissan, but the pament of the civic si was just a bit to much for my liking. thanks again
Old Aug 1, 2003 | 06:38 PM
Pelican's Avatar
Default Re: SR20DET, help on turbo pick (turboex)
Sc61.
HKS is too expensive
Old Aug 1, 2003 | 08:18 PM
Full-Race Javier's Avatar
whats wrong with the almighty t25/28
60-1 pica
Old Aug 1, 2003 | 08:19 PM
Mr. Softee's Avatar
Default Re: SR20DET, help on turbo pick (javierb14)
javier that car is sick. did geoff send you the sr20 rom editor isent him?
Old Aug 1, 2003 | 08:23 PM
GSRswapandslow
Guest
Posts: n/a
60-1 is junk.....effiecney starts at 10psi, I hate that.
go with an SC61 or 63....or be a big baller and get a GT30
Old Aug 1, 2003 | 08:24 PM
boosted92's Avatar
Default Re: SR20DET, help on turbo pick (94goldjungsr)
SC61 fo shizzle. It'll support 500+ to the ground, has a very broad efficiency range, and will spool quicker than a 60-1
Old Aug 1, 2003 | 08:31 PM
Tofurky's Avatar
wish i had your problems. deciding which turbo to get. hehe.
i'm currently about to drop in an sr20det into an AUTO 1989 240sx coupe....
you have no idea how much work it is, converting to 5 speed
Old Aug 2, 2003 | 01:24 AM
turboex's Avatar
Default Re: SR20DET, help on turbo pick (Tofurky)
Yeah the auto to man is a biatch, i hear ya there. Mine has been running for about 8 months i drive it to work everyday. very reliable car, never had to touch the motor excep for a boost leak (loose hose clamp). The other thing in that i dont have to much room to play with so i wanted the v-band setup. I am told the t4 exhaust housing on the sc61 comes with a v-band, but my manifold is for a t3. Hum pluss the v-band adapter thing is just going to take more room. what does the sc61 use for a flange on the exhaust when you get the t3 setup? a 5 bolt?
Old Aug 2, 2003 | 03:01 AM
Dee's Avatar
Dee
A friend here in Okinawa made 399whp from with an HKS T04S (60-1 blade in an AR.70 housing). Limiting factors were the small ex housing (O trim AR.50) and the 60mm portion of the DP. He is looking to upgrade to an AR.58 housing and 76mm DP. With the those upgrades, more tuning and installation of the HKS stage III cams he will apex 500whp with no problems.
Old Aug 2, 2003 | 03:49 AM
ffgeon's Avatar
yes, the sc-61 uses a 5 bolt exhaust housing. how much power are you looking to make exactly? maybe we can interest you in a small hair dryer?
Old Aug 2, 2003 | 04:12 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote">I am told the t4 exhaust housing on the sc61 comes with a v-band, but my manifold is for a t3.</TD></TR></TABLE>
Get one of my adapters...t3 to t4 or t4 to t3 if you choose
Old Aug 2, 2003 | 06:37 AM
turboex's Avatar
Default Re: SR20DET, help on turbo pick (Tinker219)
im shooting for 425hp-450hp. a si am keeping the bottom end stock. would the t4 be better or the t3 eshaust housing? oh whats the price on one of those hair dryers?
Old Aug 2, 2003 | 07:15 AM
DRAGLS's Avatar
a local guy with a red top is using a to4e 50 trim t3 stage III .63 a/r and is making 470 hp at 24 psi with a jim wolf ecu...
Old Aug 2, 2003 | 08:43 AM
VaporTrail's Avatar
New User
Default Re: SR20DET, help on turbo pick (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">a local guy with a red top is using a to4e 50 trim t3 stage III .63 a/r and is making 470 hp at 24 psi with a jim wolf ecu...</TD></TR></TABLE>
Err, no. Enjuku is running a stage 5 wheel, and management is the Power FC, tuned by Secret Service's guru Enthalpy
Old Aug 2, 2003 | 08:49 AM
VaporTrail's Avatar
New User
do you want that level on pump gas?
What is your head set up (cams, intake manifold)? What are you running for engine management? Theres more to it than slapping on a big turbo and throwing some fuel at it. Especially if you want it to be reliable.
Old Aug 2, 2003 | 12:52 PM
turboex's Avatar
Default Re: SR20DET, help on turbo pick (VaporTrail)
just greedy intake manifold, dont worry it will all be tunned issac form elite motorsports they have a few sr20's pushing over 400 hp, so im not worried in that department. I would like at least 350 on pump gas. Also yeah i know i will need more parts cams and stuff but i want the get the right turbo first rather than trying to sell the wrong one later. whats the power diffrence in say a t3/04 and a sc61 is the sc61 worth the extra money?
Modified by turboex at 10:04 PM 8/2/2003
Old Aug 2, 2003 | 12:59 PM
done's Avatar
get a nice t3/t4, or something balling if your a baller, like hks 3040
Old Aug 2, 2003 | 01:42 PM
kpt4321's Avatar
If you don't want to spend a ton of money, get a 50-trim compressor wheel and whatever hot side stuff you want. The 50 trim is BY FAR the best wheel for all-around performance, and is capable of almost 500 whp on a 2.0 liter.
If you want to go better than this, then I would suggest one of the GT series turbos. The GT35 or the GT35R is probably the size range you'd want.
Old Aug 2, 2003 | 01:49 PM
turboex's Avatar
Default Re: (kpt4321)
something like this
http://store.yahoo.com/cheaptu....html
Old Aug 2, 2003 | 01:51 PM
turboex's Avatar
or like this
TeStUdO's Avatar
Damian quit being cheap and buy the sc61
anyway im waiting for my block to come back from GE now, so ill be talkin to you soon.
Old Aug 2, 2003 | 01:59 PM
turboex's Avatar
Default Re: (TeStUdO)
Dude i just spent $275 on a 91 dodge daytona turbo for a my winter beater car, auctions rule, so thats money from my turbo so i have to be a bit cheaper. LOL
Old Aug 2, 2003 | 02:01 PM
TeStUdO's Avatar
what about the escort? mine works fine
Old Aug 2, 2003 | 02:03 PM
turboex's Avatar
I traded that for a 79 gmc jimmy, and then i sold it as it got baad gas milage. I only needed it to pickup my front clip. Torr has the escort now but the tranny took a **** last week, he got a 88 ford temp for $110 at the auction today. fords rule
Old Aug 3, 2003 | 12:56 AM
VaporTrail's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote">just greedy intake manifold, dont worry it will all be tunned issac form elite motorsports they have a few sr20's pushing over 400 hp, so im not worried in that department. I would like at least 350 on pump gas. Also yeah i know i will need more parts cams and stuff but i want the get the right turbo first rather than trying to sell the wrong one later. whats the power diffrence in say a t3/04 and a sc61 is the sc61 worth the extra money?
Modified by turboex at 10:04 PM 8/2/2003</TD></TR></TABLE>
with stock cams GReddy intake manifold isn't helping you at all. You do realize this, right? The Sc61 is WAY over kill for what you are trying to do. A SC50 would do what you want without the lag of the sc61. So would a GT2835 or a GT25R
