Spal 13" fan
Old Aug 21, 2008 | 02:27 PM
Dave_yd's Avatar
Default Spal 13" fan
hi,
i wan to buy a 13" puller fan for my turbo project, im just wondering do you have to buy the relay loom etc. or can you just cut and join wires from the OEM loom?
thanks
Dave
Old Aug 21, 2008 | 03:21 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Spal 13" fan (Dave_yd)
You can just cut the wires from your stock plug and connect them.
Old Aug 21, 2008 | 06:06 PM
95dc2teg's Avatar
Default Re: Spal 13" fan (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">You can just cut the wires from your stock plug and connect them. </TD></TR></TABLE>
thats correct! i just got this fan 3 weeks ago and i must say that it is a BADASS fan! you will have to put a bigger fuse for the fan because the stock 20amp fuse will blow, im using a 30amp fuse and its fine now. definately get it!
Old Aug 21, 2008 | 06:17 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
its best to run a relay with that fan
Old Sep 1, 2008 | 09:27 PM
g2daturbo's Avatar
Default Re: (HybridcivicLS-T)
not to thread jack but what would u recommend the spal or the fal fan?
Old Sep 1, 2008 | 11:41 PM
smoovy's Avatar
Default Re: (g2daturbo)
I've been using Fal with mine because it has a shroud, but am very interested in this spal. it doesn't have a shroud but that would be cool to have some type of groupbuy for these fans and shrouds for the civic half rad. this fan moves alot more CFM than my Fal that's for sure.
Old Sep 2, 2008 | 05:20 AM
tony1's Avatar
Default Re: (smoovy)
We build a lot of shrouds for the Spal fan, and i'd do a big run of them but it won't fit with most people's setups.
Old Sep 2, 2008 | 06:38 AM
dpetro1's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We build a lot of shrouds for the Spal fan, and i'd do a big run of them but it won't fit with most people's setups. </TD></TR></TABLE>
do you mean that the fan wont fit or the shroud setup? some people have told me that the fan fit with no problem but its seems pretty big too me
Old Sep 2, 2008 | 06:58 AM
tony1's Avatar
Default Re: (dpetro1)
Fitting the fan with a decent shroud takes up a fair amount of space.
Old Sep 2, 2008 | 07:35 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
im going to build one
Modified by HybridcivicLS-T at 8:32 PM 9/24/2008
Old Sep 2, 2008 | 08:37 AM
rorik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo &raquo;</TD></TR><TR><TD CLASS="quote">not to thread jack but what would u recommend the spal or the fal fan?</TD></TR></TABLE>
I have a flex a lite and loathe it. Every time it comes on, I can feel it in the steering wheel, and if I'm idling at a certain rpm, it's vibration combines with the motor's vibration and creates a weird resonance that vibrates the whole car. Airflow inferiority aside, that's enough for me to want to change it right there. Why they don't balance them is beyond me.
Hopefully the spal doesn't do that..
Old Sep 2, 2008 | 08:47 AM
tony1's Avatar
Default Re: (rorik)
HAHA, my FAL was the same way, always knew when it was on! lol The Spal on my car now is very smooth.
Old Sep 2, 2008 | 03:45 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (tony1)
i dont have that problem.....or maybe i have noticed.
Old Sep 2, 2008 | 06:20 PM
rorik's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">HAHA, my FAL was the same way, always knew when it was on! lol The Spal on my car now is very smooth. </TD></TR></TABLE>
Glad to know I'm not the only one..lol
Old Sep 2, 2008 | 06:42 PM
95dc2teg's Avatar
Default Re: (rorik)
my spal is very smooth as well, and for the money it really cant be beat.
Old Sep 2, 2008 | 07:37 PM
boostismycrack's Avatar
E-thug
Default Re: (tony1)
Tony, if I could make mine fit and you know very well how cramped my engine bay is, why do you think it wouldn't fit most people's setups?
Old Sep 2, 2008 | 07:43 PM
tony1's Avatar
Default Re: (boostismycrack)
We went through a lot of effort to make your setup fit. Most people look at things the wrong way. They buy whatever they can find on the turbo side of things and the cooling system gets sacrificed and whatever fits is what they're left with. "that's all i can fit" is usually the mentality. The turbo system should be designed around the cooling system, not the other way around. It's much easier to fab and move turbo stuff than it is cooling stuff. A fan and a radiator are big, not a ton of places you can put them.
Old Sep 2, 2008 | 07:57 PM
E-thug
Default Re: (tony1)
So when you says "most peolple's setups" you mean the big turbo stuff for the most part? If you thought my setup was tight before, I need to send you the pics of how it is now...
Old Sep 2, 2008 | 08:04 PM
tony1's Avatar
It's usually just something dumb like buying a manifold and downpipe from someone working on an engine stand in their garage. They get it in a car and the downpipe is RIGHT where the fan needs to go. Setups that could easily be built around a proper fan setup, they just aren't. Hell, most people can't even fit the FAL fan setup and the 13" spal with shroud takes up quite a bit more room.
Old Sep 2, 2008 | 08:08 PM
E-thug
Default Re: (tony1)
I hear ya, I have been battling engine temps as long as the car has been boosted, so I was hellbent on making the fan fit. Came out good tho. Hopefully I can get home soon and drive the car around and post some results...
Old Sep 3, 2008 | 12:24 AM
smoovy's Avatar
T1 can you give basic dimensions on your shrouds with the spal fans? FAL to my knowledge is the only one that supplies a shroud for there fans.....there's some Dough to be made. I'll admit, my FAL just doesn't move enough CFM. it works but there are improvements to be made. shoot I'll change around my set-up for better cooling. I even considered trimming my core support to move my radiator forward some and tuck it.
Old Sep 3, 2008 | 07:21 AM
E-thug
I would imagine each fan shroud is different depending on the radiator you have. Here is a pic of the shroud tony built for my C&R radiator. The fan in the pic is a 12" spal slim line rated for like 800cfm. It now has the spal high pefrormance 13" rated for 1710cfm. It is similar in size but the motor sticks out of the fan housing another 1.5" or so. I'll get a pic up of that later.
Old Sep 3, 2008 | 07:33 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
wow that's close proximity. yeah my fal works but i know the spal would be better.
Modified by HybridcivicLS-T at 8:34 PM 9/24/2008
Old Sep 3, 2008 | 07:58 AM
E-thug
Dude, if I can make it fit, u can make it fit. Get the 13", you won't regret it. The 12 is only rated for 1300ish cfm...
Old Sep 3, 2008 | 08:06 AM
E-thug
I'm sure this will work, but i would be concerned with the wires and stock relay getting very hot. I used a relay and 10 ga wires to be sure. The stock wires are only capable of delivering so much current and probably won't give you maximum performance out of the fan.
