SOHC Greddy Kit on B16
It's a SOHC greddy kit using a hks dohc manifold going into a 92 VX hatch w/B16 SIRII. Can the sohc black/blue box be used or will I have to go with a missing link and so on?
Thanks for the help!
You can use the black/blue box... but I wouldn't.
Run a 12:1 FMU w/ stock injectors or 310cc injectors with a 8:1 disc... I'd also recommend a VAFC if possible to lean out the lower RPM range.
Others may recommend then VAFC "hack", but I personally would not. Buy a Hondata Stage 2... can't go wrong for the money.
Thanks! I'm looking for something to use just to get by with 5-6 pounds until I can build up the fuel system. Hopefully since I can get the kit so cheap it will be a decent setup for a quick spool kit.
i believe the single cam kit on a b16 is not going to be the best combo. That turbo already runs out of steam on a single cam up top. A b16 revving to 8k might not be exactly efficent. Not from experience but just an idea
I'm still planning on a b-series turbo kit but since the price of new and used sohc greddy kits are so cheap if one comes along I may pick it up. I figure it would be a good around town turbo with quick spool up and a little more power in the 1/4. I'm pulling 14.2's now so i'm sure I could get mid 13's at least on the litte sohc kit.
Thanks for the input guys! Keep em coming!
khang77642
Jul 13, 2002 04:09 PM
