Re: Slow building boost after external wg install.
is it possible for you to borrow someones tial wg just to see if you have a bad one?
Does a 38mm Tial spring fit my 35mm Tial wastegate?
Also what is the difference between the big and small springs? |
I'm new to the turbo world, but if you have a 4psi spring in there then wouldnt full boost be 4psi?
Originally Posted by Eli2
(Post 42502606)
also if your building 5psi with a 4psi spring and still building it after it already hit 5 your having some major boost creep issues whether its slow or not |
Thats what I was thinking, so actually hes not having problems building boost slowly since it hits 5psi pretty quick and after that its just boost creep.
If you read my first post a mention I am tuned on 9psi. I have a mbc.
I didn't notice it the way you worded it. Greddy 15g 9psi I was like what?
I changed the spring to an 8.7psi spring and it builds boost alittle faster but not by much?
bump
Originally Posted by zach1288
(Post 42628136)
bump
check the flapper
Originally Posted by azandford
(Post 42629387)
do a compression check on your motor.... low compression might be the cause of this
Any other suggestions?
So ur not checking the flepper?
Originally Posted by turbohatch96y7
(Post 42722346)
The external wastegate piston and seals are perfect as far as I can tell. |
(Post 42502788)
(Post 42616508)
You had a 4lb spring before. It built 4lbs quickly then slowly increased after that. Like mentioned before, it sounds like boost creep You added an 8.7psi spring. Does it now build 8.7psi then continue to creep after that? It just sounds like your MBC doesnt work properly. I really dont see the confusion here. You had a 4psi spring and it built 4psi...exactly what is supposed to happen (without an MBC), then it was just boost creep after that. Get another MBC and see if that helps, or just run off the 8.7psi spring without the MBC |
couldnt youhave just run a boost controller to the internal WG and up the boost that way rather than get an external and welt the internal one?
(Post 42723239)
The internal wastegate flapper is welded shut perfectly as far as I can tell.
The external wastegate piston and seals are perfect as far as I can tell. Now a run down of slow building boost could be. A bad blow off valve Cracked exhaust housing Boost leak in charge pipes |
Originally Posted by viper_boy403
(Post 42725956)
Ok let me get this straight here...
You had a 4lb spring before. It built 4lbs quickly then slowly increased after that. Like mentioned before, it sounds like boost creep You added an 8.7psi spring. Does it now build 8.7psi then continue to creep after that? It just sounds like your MBC doesnt work properly. I really dont see the confusion here. You had a 4psi spring and it built 4psi...exactly what is supposed to happen (without an MBC), then it was just boost creep after that. Get another MBC and see if that helps, or just run off the 8.7psi spring without the MBC It boosts quickly to 4-5psi then slowly builds to 9psi, but never goes over 9psi. |
(Post 42730109)
Okay well first to check the wategate you have to put some pressure in there and see if it leaks..
Now a run down of slow building boost could be. A bad blow off valve Cracked exhaust housing Boost leak in charge pipes If the exhaust housing was cracked wouldn't I hear it? I already pressured tested the whole system, no leaks. |
not really i seen some of those 14b turbos and i always see cracks on the inside and outside very small but still there..if you already pressure tested all the piping then i guess your bov is okay..
Is there a way to test for leaks from the turbo/exhaust manifold?
Is there a way to test for leaks from the turbo/exhaust manifold???
are you reusing a gasket? replace the gasket and just make sure everything is nice and tight.
Originally Posted by per4mance
(Post 42473470)
did you install the fire ring on the wastegate?
