Slow building boost after external wg install.
I installed an external wastegate and when I WOT the car it sticks at 5psi for a long time then builds boost very slow. I removed the vacuum source to the Tial and it built boost very fast but of course hit boost cut. What would be causing this?
My setup: D16y7 Greddy 15g 9psi Tial 35mm TurboXS MBC |
Re: Slow building boost after external wg install.
bump
Where do you have the line for the wastegate getting its boost signal from?
Originally Posted by viper_boy403
(Post 42464129)
Can you move the boost signal line closer to the wastegate? Like directly off the turbo housing?
Mike |
Originally Posted by 89efhatch
(Post 42464219)
Mike |
Shortest possible line to the wastegate seems to work best. The boost signal off the compressor housing is right there and accurate.
Mike |
It sounds like the waste gate isnt closed all the way. Or theres a leak.check to see if the wastegate is leaking or take off ur dump tube and see if its closed all the way
(Post 42464411)
Mike I changed the vac source to the compressor housing and it did not change anything. It must be a boost leak somewhere. |
How can there be a boost leak if when u take the vac line off it hits ur boost cut? Check the waste gate
Or maybe ur exhaust housing is cracked. Did ur turbo have a flapper before?
Was the TiAL wastegate new? Even if it was, did you even bother inspecting it internally to make sure the valve, diaphram, etc. are in fine working condition?
The excess vacuum line from back at the manifold to the wastegate has the potential to slow spool down a bit, but not how you describe, and it will account for any boost that is lost between the compressor housing back to the throttle body. Running the line from the compressor housing, the wastegate will still see 9 psi, but that doesn't always mean that's what is present in the intake manifold. Just food for thought for you. :) |
Do a boost leak on the car
Originally Posted by turbohatch96y7
(Post 42467936)
Originally Posted by Honda Bull
(Post 42468408)
I would take it apart and recheck it..
did you install the fire ring on the wastegate?
Have you changed your downpipe since you installed the external WG? I installed my turbo setup and I didn't run a downpipe and it took forever to build boost. Once I had one fabricated it hit the desired boost level much faster. Make sure that you have a properly sealed downpipe.
Good luck, Blaze |
what spring is in the wastegate? it kind of sounds like it has a 5psi spring in it and then the additional boost that starts coming slowly might just be boost creep.
Originally Posted by tofast4uh22
(Post 42476235)
It is a 4psi spring. Should i get an 8psi spring?
Bump
yes. but only if that is the lowest target boost that you will want to see.
Originally Posted by 98exn20
(Post 42485272)
