Showing 10psi but......
Old Aug 7, 2004 | 08:39 PM
silverintegra83's Avatar
Default Showing 10psi but......
hey guys i recently got my turbo setup working. dyno tuned and it was pulling HARD at 9-10psi. i mean you def. know and feel the pull. well juz yesterday and tonite at don't feel it anymore, i mean i get on it and the boost gauge shows 10psi but i juz don't feel it pull like b4. everything seems to be correct. has anyone had this problem? please help any input would be appreciated.
thanh
ps. i can hear the turbo spool but juz not pull like when i 1st got it on.
Old Aug 7, 2004 | 08:42 PM
DubyaAye's Avatar
Default Re: Showing 10psi but...... (silverintegra83)
its time to turn up the boost
Old Aug 7, 2004 | 08:50 PM
AspectIndustries's Avatar
Default Re: Showing 10psi but...... (DubyaAye)
lolz, dude! I know how you feel exactly!
I don't know if im used to the pull.. Or is it my car slowing down? I dont feel the rush any more either!!! WTF?!??!
Am I on the road to think " Once you get fast, you will want to go faster! " Because I cant feel it any more!@ But sure do i Kick lot of asses though.
lol. i dont think thats it. i juz got my car boosted on thursday. i know i am not use to it in 1 1/2 days. i know it is something to do with my engine somewhere or somewhere in my setup. any other insight?
thanx
Old Aug 7, 2004 | 09:13 PM
dunkd's Avatar
maybe plugs are fouled?
Old Aug 7, 2004 | 09:31 PM
Default Re: (dunkd)
damn. that might be it. imma check that out tomorrow. thanx man
Old Aug 7, 2004 | 09:35 PM
turbo*s2k's Avatar
Default Re: (silverintegra83)
yeah check the plugs... You do get use the power though after awhile, but not in 1 1/2 days...
Old Aug 7, 2004 | 10:54 PM
m R g S r's Avatar
Was it really hot? Because if it was cool one day and really hot the next that makes a very big difference.
Old Aug 8, 2004 | 01:35 AM
adseguy's Avatar
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Was it really hot? Because if it was cool one day and really hot the next that makes a very big difference.</TD></TR></TABLE>
Exactly what I was going to say. Drive your car a cool night during this summer and then see if it pulls. You might be getting used
Old Aug 8, 2004 | 02:02 AM
Kwuaymaikrup's Avatar
Default Re: (adseguy)
Where are you tapped for the boost guage? Maybe it is a boost leak? I highly doubt it though. I would say plugs. What is the setup? I am running 1000cc injectors being fed by an Aeromotive pump, if I stall my car even one time I instantly foul my plugs.
Old Aug 8, 2004 | 03:44 AM
Siriuswerks's Avatar
check your piping same thing happened to me the silicone coupling was leaking
Old Aug 8, 2004 | 03:48 AM
Boosted Chemist's Avatar
Default Re: (SiRiUsWeRkS)
i had a simiar problem and then i saw i blew a wastegate gasket and one off the bolts had backed it self. This caused the turbo to spool alot later adn mad it slow as **** (relative to before)
Old Aug 8, 2004 | 07:10 AM
m R g S r's Avatar
Default Re: (Mad Chemist)
You should hear an exhaust leak if that was the case. . . .
Old Aug 8, 2004 | 07:57 AM
Default response
m R g S r: i drove it at night in very cool weather.
Kwuaymaikrup: boost showing 10psi so i don't think it is a leak anywhere. my setup it
b16a1
t3/t4 turbo
vafc
dsm 450cc
tial 35mm wastegate
no fmu
SiRiUsWeRkS: my piping seems to be okay. when i had a leak (my 90 degree elbow ripped) i was losing boost. so if i had a leak i would lose boost right?
Mad Chemist: how would i know this happens?(im still a noob sorry)
thanx guys.
thanh
Old Aug 8, 2004 | 09:43 AM
Default Re: response (silverintegra83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverintegra83 &raquo;</TD></TR><TR><TD CLASS="quote">m R g S r: i drove it at night in very cool weather.
b16a1
t3/t4 turbo
vafc
dsm 450cc
tial 35mm wastegate
no fmu
thanx guys.
thanh</TD></TR></TABLE>
look at the bolts that hold on hte wastegate and maybe check hte gasket, a little blue thread lock helped me out
Old Aug 8, 2004 | 10:37 AM
Default Re: response (Mad Chemist)
well im goin to hope its the plugs!!! if not that would really suck. what am i suppse to gap the plugs to? i forgot it was either 32 or 30 i think. anyone know exactly?
Old Aug 8, 2004 | 11:06 AM
99B16Si's Avatar
.028-.030 is what id do for stock ignition and about 10psi.
also id hate to make this an added possiblilty but when ring lands crack sometimes you wont even notice except for a slightly loss in power. a compression test will tell u for sure tho. couldnt hurt to check
Old Aug 8, 2004 | 12:03 PM
DruWO's Avatar
Default Re: response (99B16Si)
if your ring lands cracked...you'd notice smoke coming out of your breather. might want to check for that too...
Old Aug 8, 2004 | 12:50 PM
Default Re: response (DruWO)
thanx guys no smoke here. so thats good. gonna do plugs after i get off work.
Old Aug 8, 2004 | 01:08 PM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DruWO &raquo;</TD></TR><TR><TD CLASS="quote">if your ring lands cracked...you'd notice smoke coming out of your breather. might want to check for that too...</TD></TR></TABLE>
not always true.
check for an exhaust leak, either at the turbo to manifole, or the turbo to downpipe, or wastegate.
Landon
Old Aug 8, 2004 | 03:30 PM
well i changed the spark plug. still the same.god i dont know what to do. ***!!!!!!! when i was taking off my friend said there was A LOT of smoke coming out of the exhaust. any suggestions?
Old Aug 8, 2004 | 04:19 PM
kabaroo's Avatar
do a compression test ASAP
Old Aug 8, 2004 | 05:23 PM
Jim Truett's Avatar
Default Re: (kabaroo)
Do a compression test. You have very poor fuel management, so I am inclined to think you may have melted a piston.
Old Aug 9, 2004 | 10:02 AM
bump.
Old Aug 9, 2004 | 11:25 AM
kabaroo's Avatar
have you done a compression test yet?
