shim or not to shim?
Old Apr 1, 2009 | 02:34 PM
TcUiRvBiOc's Avatar
Default shim or not to shim?
a friend of mine told me i need to shim my oil pump, he did it on his setup and said it worked great, ive heard of people using washers but he said just put a 10mm nut on the spring.. what do u think? im gonna tune to 20 lbs and was wondering if shimming the oil pump is something that needs to b done on a setup like this? any input would b great thanx
heres my setup
b18a1 stock bore golden eagle sleeves
supertech 10.1 pistons eagle rods ls crank
type r oil pump
b16 head supertech springs and retainers gsr cams
ge fuel rail and srd fpr walbro 255hp
type r im and tb
gt40 turbo with sls ramhorn
tial 38 with 1 bar
tial bov
3 bar
2.5 ic piping
11x31x3 ic
3 inch dp and exhaust
1000cc precisions
and ima set the redline at 8500 i think
Old Apr 1, 2009 | 03:05 PM
Turbo-LS's Avatar
Default Re: shim or not to shim?
alright ill be the first to say it
Shim the oil pump ??????????????????????
Old Apr 1, 2009 | 03:06 PM
steveo135's Avatar
and i'll be the 2nd
Old Apr 1, 2009 | 03:07 PM
AbitAvenger's Avatar
do what?
Old Apr 1, 2009 | 03:10 PM
Ramma's Avatar
...... Wait wut?
Old Apr 1, 2009 | 04:08 PM
TcUiRvBiOc's Avatar
so yes on shim? is 10mm nut to thick of a shim?
Old Apr 1, 2009 | 04:11 PM
'94civic b16's Avatar
If I'm not mistaken he is referring to shimming the bypass spring mechanism inside the oil pump to increase the pressure the pump produces.
Old Apr 1, 2009 | 04:15 PM
93egSLEEPER's Avatar
never heard of this before. i am interested in the piston choice as well. 10:1 compression forged pistons for a turbo build? why not 9:1?
Old Apr 1, 2009 | 04:42 PM
non-VTEC's Avatar
if you add a .050" thick washer you may gain 10-15psi of oil pressure.
Old Apr 1, 2009 | 04:50 PM
TcUiRvBiOc's Avatar
they r 10.1 for a ls motor, i have a b16 head and itll b around 9.6 to 1.. higher compression helps spool the turbo quicker, we have a real good tuner up here and all my friends setups r atleast 10.1 and have done great so thats what i chose to do
Old Apr 1, 2009 | 05:06 PM
Turbo-LS's Avatar
if they are ls pistons the b16 head has smaller combustyion chambers which will raise compression
that being said your compression will be 10.1:1 . 10.1 is fine for boost. if you have a good tuner you can runer highe rcompression on pump gas and make really nic epower. lower compression will just take more timing to compensate and make about the same power and the 10.1 will give it better low end when out of boost than the 9.6. im running 10.6:1 in my car daily driven 16 psi on an sc63 pump gas no problems
Oh and dont touch the oil pump
Old Apr 1, 2009 | 05:16 PM
TcUiRvBiOc's Avatar
yeah id like around 10.1 but when i enter what i got on the c-speedracing chart it says its 9.8:1, i dunno either way its fine.. thanx
Old Apr 1, 2009 | 09:17 PM
TheShodan's Avatar
Moderator
I have had people do this on the honda motor when going NA or turbocharging. DO NOT DO THIS. This creates too much oil pressure at higher rpms with the turbocharger on, and you will blow the seals out of it, even with a -3AN line. Putting in a restrictor in the oil feed defeats the purpose of using these shims or other modifications to the oil pump or oil pick up. I've just had 2 turbo submitted to Garrett for warranty (which WILL be denied, I promise you) because oil pressure was reaching over 120psi at the line killing the turbo.
This is an unnecessary modification from the intent of Hondas design. I strongly urge against doing this modification.
Old Apr 2, 2009 | 03:59 AM
non-VTEC's Avatar
a slight bump in oil pressure never hurt anything. if you can add 10-15psi of oil pressure it would be fine.
however....if you engine is assembled correctly and your oil pump is in good condition plus you have a good oil pressure gauge and its making over 75psi then this mod is unnecessary.
Old Apr 2, 2009 | 05:33 AM
CSaddict's Avatar
None of this makes any sense. You shim it for the oil pressure for the motor, not the turbo. You should always run a restrictor with or without shimming the pump.
Old Apr 2, 2009 | 06:25 AM
Turbo-LS's Avatar
THANK YOU !!! Finally someone agress with me LOL
Old Apr 2, 2009 | 07:18 AM
blaze the chemi's Avatar
This is something that the NA guys have done for years. Yes you just add a washer between the crown of the bronze bolt and the pump. I've never heard of anyone doing this on a turbo though. Just make sure there is a good restrictor in the oil feed line. I would also test the pressure of the line between the oil restrictor and turbo just to make sure there isn't too much just to be sure.
Old Apr 2, 2009 | 08:10 AM
TcUiRvBiOc's Avatar
good so shimming is bad thank u.. so i run a restrictor in between the feed line from the block to the turbo? where do i get a restrictor for this?
Old Apr 2, 2009 | 08:11 AM
TcUiRvBiOc's Avatar
and how much oil pressure is too much for a turbo? i have a fast turbo feedline kit doesnt that come with the restrictor?
Old Apr 2, 2009 | 08:48 AM
non-VTEC's Avatar
the turbo only needs 40-50psi MAX. even less if it's a ball bearing CHRA.
Old Apr 2, 2009 | 10:10 AM
TcUiRvBiOc's Avatar
ok i was reading that u really only need a restrictor for bb turbos and that as long as i have a big return line it will keep the oil pressure from getting too high for my journal turbo. its a -3 feed line and -10 return line the kit does have a male to male fitting with a smaller hole but its not that small, dunno what the measurement is.. i had the fast turbo kit on my last car and i had no turbo issues
Old Apr 2, 2009 | 01:38 PM
Turbo-LS's Avatar
FUNCTION7 type it into search on ebay. theyn look for the size you need -3 or -4 and it will say restrictor. if none are up listed then contact them directly to get one you need a .035. gt turbos take .025
Old Apr 2, 2009 | 04:22 PM
srmofo's Avatar
Its no use man, theyll never learn.....
To the OP, why do you think you need this increase in oil pressure?
Old Apr 2, 2009 | 04:44 PM
TcUiRvBiOc's Avatar
i dont think i need to, i just heard that i should and was not sure bout it so i posted this to learn so i didnt do something stupid i know nothing about... thanx
Old Apr 2, 2009 | 05:44 PM
Pendmn's Avatar
i suggest no shim on the oil pump senior. im reading about the GT3071 turbo that ima slap on my D16y7 and pretty much says to use the .035.. ATPturbo site says the following:
Oil inlet fitting for GT Ball Bearing Turbos for GT28R/GT28RS/GT30R/GT35R with built-in oil restrictor (of .035 hole size). Custom machined part. Output is -4 AN male flare. use with any of our -4 feed line assemmblies
