is this setup safe for turbo
i need to know if this setup is safe for turbo
b20z block
11:1 cr
stock rod with arp rod bolts
ge block gaurd
p 72 head
itr cams
skunk 2 pro seris mani
68mm tb
2.5 apexi ws exahust
full race turbo kit
400cc injectors
walbro 255 fuel pump
blox fpr
aem fuel rail
hondata s100
im wondering if i run this setup on 7 psi would it be safe its a daily driven car any help would be appreciated
Modified by b20turbocivic at 9:27 AM 4/18/2007
b20z block
11:1 cr
ge block gaurd
p 72 head
itr cams
68mm tb
full race turbo kit
400cc injectors
blox fpr
aem fuel rail
hondata s100
rsx-s has the same compression ratio and people are turboing them left and right. Just tune the hell out it and it should be good.
If you want it to be a little safer throw a thicker headgasket on there to lower the comp ration.
i have an ge head gasket on it right now i really dont wanna change anything because im about to go get it tuned in a couple weeks, how much boost can i use on this setup?
i think you will run out of injector, before you make good power.
the weakness on the b20 is the sleeves remember. maybe step up to 550's, and be a little conservative especially with the static compression that high.
yea im not planning on pushing out alot of power right now what about dsm 450 would these be enough to push out about 300-350whp?
03EM2guy
24
Mar 27, 2011 07:32 AM
bradykiller
May 27, 2005 09:48 AM
