sc61 trim size
Old Apr 13, 2009 | 09:03 AM
jne's Avatar
jne
Default sc61 trim size
anybody know the trim size of the precision sc61 t3/t04e? thanks.
Old Apr 13, 2009 | 09:25 AM
twkdCD595's Avatar
Default Re: sc61 trim size
We would need to know which sc61 (sc61xx?) to tell you the turbine trim ratio as well if you wanted to know both compressor and turbine trims.
However on compressor side only, I believe they are a 56 trim.
http://www.turbobygarrett.com/turbob...tech102.html#a
Scroll down to the first section about calculating trim ratio in the above link if you want to know how to get to that answer.
Old Apr 13, 2009 | 09:41 AM
TheShodan's Avatar
Moderator
Once again, like the link in the above was posted, a larger trim doesn't necessarily mean a larger wheel for the turbocharger. The only time that holds consistently true is the 50/57/60 trim argument, and even then that is simply the for about a 20whp difference, so don't use that argument w/ the SC61XX. the differences are in the EXHAUST wheel for that series turbocharger, not the compressor wheel.
Old Apr 13, 2009 | 09:58 AM
jne's Avatar
jne
sc6169, and can you guys clear up what's the difference between e, s, and sp?
Old Apr 13, 2009 | 10:12 AM
twkdCD595's Avatar
Slight sidenote since it relates to your post. Seems very common people make assumptions like this or also its seems like it is becoming very common to see people mis-using terminology, IE... like saying trim instead of a/r. So they start calling these 70 trims all the time because they see the .70 a/r compressor cover stamping.
Old Apr 13, 2009 | 10:19 AM
twkdCD595's Avatar
sc6169 has a 69 trim turbine wheel.
"e" compressor cover... 3" inlet/ 2" outlet
"s" compressor cover... 4" inlet/ 2.5" outlet
"sp" compressor cover... ported inlet "s" cover... 4" inlet/ 2.5" outlet
Old Apr 13, 2009 | 07:09 PM
jne's Avatar
jne
thanks a lot for the help twkd really appreciate it.
Old Apr 14, 2009 | 05:37 AM
twkdCD595's Avatar
No problem... glad it helped.
the.hamburglar
Mar 13, 2008 08:32 PM
backspin88
Jun 17, 2005 08:20 PM
blackeg
Nov 15, 2004 06:05 PM
Ri5e
Sep 9, 2004 03:52 PM
PrecisionH23a
Feb 5, 2003 10:47 PM
