SC61 on D16... Don't laugh.
Old Oct 31, 2003 | 04:53 PM
M.A.R.C.'s Avatar
Default SC61 on D16... Don't laugh.
OK don't laff at the topic. Serious question here. I'm working on a built d16z6 for the next setup the motor is a GE sleeved 77mm (75mm stock) d16z6 block, JE 9:1 slugs and Eagle rods, ARP studs, cometic headgasket. The head will be stock for now just want to get the car running. I have a T3/T04E 46 trim that ill be using in the mean time as well. I was trying to look ahead and see what kinda turbo i could upgrade to in the future. I was wondering what are peoples' thoughts on the SC61 on a built D16 :uts on flame suit::. Obviously the motor would have to be able to revv pretty high to make usable power. Not trying to look for "the biggest turbo i can fit on the car" just looking for a good sized turbo to make use of the motor. i've seen a couple 450 and 500whp d-series... wondering if i could get close hehe.
Old Oct 31, 2003 | 04:55 PM
liam821's Avatar
25 Year Member
Default Re: SC61 on D16... Don't laugh. (CivicRyda2k)
i wanna get a SC61 for my ZC sometime...
liam
Old Oct 31, 2003 | 04:58 PM
djdxm's Avatar
If i can put a PT67 on my motor, why couldnt you put a SC61 on urs? It may be laggy, but i have seen a few D series w/ 60-1's. Like the Zex CRX. It runs a 60-1 (i believe full T4) which would be crazy. But it all depends on your goals. I have heard that the SC61 spools quicker than a 60-1? If not you could also get a .48ar, it may hamper top end but it would help you get it spooled up.
Here is a link on the Zex CRX
http://www.zex.com/Community/Gallery/
I say go for it!
Old Oct 31, 2003 | 05:00 PM
M.A.R.C.'s Avatar
Default Re: SC61 on D16... Don't laugh. (djdxm)
yah very true. just wish i had compressor maps for the sc61
Old Oct 31, 2003 | 05:07 PM
norcalcrx's Avatar
On the built d16 i am building i am using an SC50 with a .63a/r. It will be interesting to see what it does.
Old Oct 31, 2003 | 05:12 PM
Disco Stu's Avatar
Also, I think a hardcore port and polish job on the head would be VERY crucial to getting that thing spooling before redline. I'd try one on my d series if I had the money.
Old Oct 31, 2003 | 05:16 PM
M.A.R.C.'s Avatar
Default Re: SC61 on D16... Don't laugh. (Disco Stu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Stu &raquo;</TD></TR><TR><TD CLASS="quote">Also, I think a hardcore port and polish job on the head would be VERY crucial to getting that thing spooling before redline. I'd try one on my d series if I had the money.</TD></TR></TABLE>
oh yah most definitely
Old Oct 31, 2003 | 05:47 PM
M.A.R.C.'s Avatar
up! i was expecting more controversial reply but oh well. any care to contribute?
Old Oct 31, 2003 | 05:53 PM
M.A.R.C.'s Avatar
also considering a larger t3/t04e. like i said just something that will support more power than the 46 trim i have here without going overboard
Old Oct 31, 2003 | 08:55 PM
Drew Peacock's Avatar
Default Re: SC61 on D16... Don't laugh. (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">On the built d16 i am building i am using an SC50 with a .63a/r. It will be interesting to see what it does. </TD></TR></TABLE> Whats the sc50 top out at? I wouldn't go so big as a Sc61 when you don't need to. The sc50 would flow 500whp would it not? I would rather run more boost and have less lag.
Currently I have a Ball bearing IHI VF22 its flows 400hp and starts spooling around 3000rpms. I am still running a stock block so have only run upto 12psi the turbo is not in its effiency range yet and will not stay spooled up all the way to redline. Going to big is a pain in the ***.
Old Oct 31, 2003 | 10:24 PM
ITRswapandslow's Avatar
Matt Patrick has some work beign done right now...and it WILL be faster when it comes back out.
Hehe...i know what he's getting...and he don't even know me.
Old Nov 1, 2003 | 12:37 AM
SiR Kid's Avatar
New User
Default Re: (eh2nboost)
Matt Patrick was using a smallish T4 last year, with the Nitrous to help spool it.
I was tlaking to him at the NOPI Drag Wars in St Louis about the car... He said he was happy with the way it was running....
Well, that was 3 months ago!
Maybe I'll go by Comp Cams and see him... haven't really shot the **** with him in 2 years now.
Old Nov 1, 2003 | 07:44 AM
Boltz's Avatar
Default Re: SC61 on D16... Don't laugh. (turbozxi)
sc50 wont make 500whp..... the sc32 which is bigger is supposed to max out around 480 horsepower, i would also guess that is flywheel horse
Old Nov 1, 2003 | 07:52 AM
norcalcrx's Avatar
Default Re: SC61 on D16... Don't laugh. (BoostRotter)
I believe the sc50 is good for 400+whp. I talked with Rod at Precision and he recomended this turbo for what we are looking for, which is about 350whp @15 psi. He said that this would do the trick.
Old Nov 1, 2003 | 07:53 AM
ELSpool's Avatar
From what I have been told, the 50 trim wheel is probably the best for the d-series. That being said, there are guys running bigger, I have the 57 trim for mine, but if I could switch I would go a tad smaller. I only plan to hit 300whp and that it. No race gas, nothing more. So for me the 50 trim is ideal. But if you looking to run the race gas and up the boost, I would go bigger.
Old Nov 1, 2003 | 11:12 AM
M.A.R.C.'s Avatar
Default Re: (ELSpool)
yah that's what i'm looking for... big power (for a sohc)
Old Nov 1, 2003 | 12:39 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">From what I have been told, the 50 trim wheel is probably the best for the d-series. That being said, there are guys running bigger, I have the 57 trim for mine, but if I could switch I would go a tad smaller. I only plan to hit 300whp and that it. No race gas, nothing more. So for me the 50 trim is ideal. But if you looking to run the race gas and up the boost, I would go bigger.</TD></TR></TABLE>
I run a 60 trim .63 ar turbo at 12.5 lbs on a stock Z6 block (no head gasket, no head stud, nothing) and the car flies. Once the motor goes in, I plan on big power as well. I think this turbo is enough for me, but that is what they all say!!
Old Nov 1, 2003 | 02:27 PM
Default Re: (ladysman)
I got mixed up a little there there Precision's turbo sizing numbers are weird. How about a SC34 or SC52 should do nicely???
http://www.precisionturbo.net/...eries
Old Nov 1, 2003 | 02:45 PM
M.A.R.C.'s Avatar
yah i'm considering a 60 trim as well
Old Nov 1, 2003 | 04:13 PM
Default Re: (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Matt Patrick was using a smallish T4 last year, with the Nitrous to help spool it.
Maybe I'll go by Comp Cams and see him... haven't really shot the **** with him in 2 years now.</TD></TR></TABLE>
you'll see a LOOOOOOOTTTTTTT more out of that car as soon as the new parts get on. I promise that.
Old Nov 1, 2003 | 07:55 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
I run a 60 trim .63 ar turbo at 12.5 lbs on a stock Z6 block (no head gasket, no head stud, nothing) and the car flies. Once the motor goes in, I plan on big power as well. I think this turbo is enough for me, but that is what they all say!! </TD></TR></TABLE>
When are you hitting boost with that setup?
liam
Old Nov 1, 2003 | 07:57 PM
liam821's Avatar
25 Year Member
Im gonna totally agree on this. Im not really sure how much a stock sohc head can flow..but im sure its nowhere near the b-series. You are going to need to work the head heavly to flow that much air...and im sure larger valves etc etc
I wouldnt see why it couldnt spool one...you might have to push the rev limiter pretty high. But that is what a built block is for.
liam
Old Nov 2, 2003 | 01:51 AM
head work would do wonders, along with a Zex 59300 cam, and that cam ONLY
you don't need valve springs though, just retainers. The stock valves are light enough to not need springs.
but, if you do any head work, make sure you start with a Z6 head. The Y8 head is WORTHLESS.
http://www.hondaraceengines.com They'll make over a SOHC head better than anyone. Hehe, someone mentioned in this thread has theirs there now. And Brad will have mine up in there soon...just so we can play around with some new ideas.
Old Nov 2, 2003 | 11:16 AM
djdxm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2nboost &raquo;</TD></TR><TR><TD CLASS="quote">head work would do wonders, along with a Zex 59300 cam, and that cam ONLY
Definately gonna make a big diff. Also remember ya can always fix lag with a little NOS .... or alot
Old Nov 2, 2003 | 11:17 AM
M.A.R.C.'s Avatar
Default Re: (djdxm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djdxm &raquo;</TD></TR><TR><TD CLASS="quote">
Definately gonna make a big diff. Also remember ya can always fix lag with a little NOS .... or alot </TD></TR></TABLE>
can't say the thought didnt' cross my mind
