sc61 with a 2.5" dp?
anyone running an sc61 with a 2.5" dp? I just got my sc61 and I didn't think that the stage 5 wheel would be that much bigger than the stage 3. also the dp flange i bought is only like a 2.375" diameter. I have a/c so 3" is kinda outta the question. anyone have a 2.5" dp (or even 3" but retaining a/c)?
so to set the facts down:
stage 5 outlet = 2.75"
dp flange = 2.375"
downpipe piping = 2.5"
dp flange = 2.375"
doesn't cause any spikes or anything?
my main concern was the edges of the dp flange basically BLOCKING flow out of the turbine wheel like this....
just a sketch but, anything outside that circle would be blocked off like this
I feel sorry for you Marc, putting that monster on a SOHC D16.
Can you open up the flange? If not, a 3-2.5 inch flare piece will work, you should have enough room then to run the rest of the DP in 2.5 inch.
checkign with my friend who has a machine shop. i was thinking it would be better to have the flange made bigger (can't go too big) but then if anything make it more of a transition to a smaller size. i dunno ill see just seeing what people think,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 »</TD></TR><TR><TD CLASS="quote">No spikes, no creeping.....Works fine, but I'm sure that I'm losing a couple of hp.</TD></TR></TABLE>
Yeah, but you are staying cool.
Smarter than you
You can run the 2.5" downpipe and its going to cause some turbulance and rob some power.... but you can still make a **** load. TurboTegB18c ran a inline pro mani w/ SC61 and 2.5" downpipe-2.75" exhaust and made 459whp @ 22psi...
Modified by DIRep972 at 8:15 PM 5/17/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostismycrack »</TD></TR><TR><TD CLASS="quote">THats what I did. Grinded out a 2.5 to 2.75, works great.</TD></TR></TABLE>
id do the same....bore it out to larger. It will work great.
Marc is such a stunna
props to my homeboy.
liam
props to my homeboy.liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">ive seen a sohc make 420 whp on a sc61 with 2.5" downpipe</TD></TR></TABLE>
yah gotta see that one. inspiration
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ek »</TD></TR><TR><TD CLASS="quote">**** i have a t3/t4 and im afraid it want spool up on my d16y8</TD></TR></TABLE>
Go with a .48A/R, full 3" dp and no restrictions exhaust and I bet that mother will spool quicker than hell. That's what I'll be doing with the SC50 that's going on my Y8.
