saving of bottom end
Old Sep 24, 2007 | 07:55 PM
thomas188's Avatar
Default saving of bottom end
Hey guys... I think I have a knock developing in my bottom end. At idle there is no noise what so ever and at startup there is no noise. I can punch the gas and not hearing anything until in the middle of rpm downfall punching it again where I hear a faint clatter. This will be my 2nd bottom end to go out if it does. This one will have lasted me about 4k miles which I am not satisfied with at all.
I have a f22a1 and Im boosting close to 10 lbs tuned on Crome.
When I put this engine in I put all new bearings in the bottom end... rod, main, and thrust washers too. Checked every tolerance 2 times and all was within spec using stock size bearings matching crank codes.
What would be causing my bearings to go when everything was in spec? Is this a knock again, I feel no power loss what so ever either.
Old Sep 25, 2007 | 12:32 PM
thomas188's Avatar
Default Re: saving of bottom end (thomas188)
It's my thrust washers again im 99.5% sure. Same thing happened last time. It gets louder in turns against my main turning axle. This is a different crank and block. Could it possibly be my clutch causing these problems?
Old Sep 25, 2007 | 02:42 PM
EASY101's Avatar
* B A N N E D *
hows the oil pump and oil pressure? just a thought...
Old Sep 26, 2007 | 07:29 AM
thomas188's Avatar
Default Re: (EASY101)
oil pump and pressure is good. 90psi cold start and around 50ish driving
gfrererr13
May 12, 2014 01:12 AM
thomas188
Sep 25, 2007 12:02 PM
projectTeG
20
May 13, 2006 01:28 PM
my4drGSR909
Jul 17, 2005 02:22 PM
blunty
Mar 30, 2002 07:18 AM
