S300 bug advise
Old Jul 6, 2009 | 05:19 AM
EddieCRX's Avatar
Default S300 bug advise
This has happened quite a few times now so more than a random occurrence.
I’m driving at a sustained cruise speed (70mph) for 10 to 15 minutes,
Not in positive boost
AFR’s are on the dot 14.7
Lift off gas for slowing traffic and AFR’s lean out to 17’s to 20’s CEL lights up,
Nothing recorded in data logs
Only way to clear the fault is switch off / on engine 3 or 4 times while cursing.
It only seems to do this once in any drive cycle, i.e. once it’s done it once in a journey it doesn’t do it again till next start up.
So it’s consistent and can be replicated
I just don’t know how to narrow down the problem with no data logs?
Done most of the obvious physical checks, ignition, leads, 02, fuel filter, new fuel pump, etc etc etc.
Built GSR
GT30
OBD1
S300
RC 750cc injectors
255 in tank
I was wondering if there could be a bug in the software or something along these lines, I’m not convinced it’s the S300 but I would like to rule it out.
Old Jul 7, 2009 | 03:24 AM
EddieCRX's Avatar
Default Re: S300 bug advise
Anyone?
Old Jul 7, 2009 | 11:48 AM
dpetro1's Avatar
what code are you getting?
Old Jul 7, 2009 | 11:56 PM
EddieCRX's Avatar
As I said in my opening post, no codes, I can't work that one one out either, car throws a cel but not recorded, data logging is working but for some reason it’s not picking this one up.
Old Jul 8, 2009 | 12:00 AM
jdm inc's Avatar
do you have the lean protection enabled? that might be causing it to throw a code.
Old Jul 8, 2009 | 08:22 AM
locash's Avatar
Turn off the lean protection if you are using it, or change the settings for it. The Honda ecu shuts off the injectors on decel, probably causing your issue..
flipldls
29
Jul 12, 2010 06:05 PM
atarigamer01
May 21, 2008 10:52 AM
fracas
Aug 17, 2004 10:28 AM
Vardoulika
Nov 1, 2003 07:07 PM
AmauryR
May 21, 2002 03:11 PM
