Running a turbo open with out a filter?
Old Jun 11, 2006 | 08:37 PM
dangerranger21's Avatar
Default Running a turbo open with out a filter?
Hopefully the title makes enough sense for you to get what I am talking about... I recently bought an Si with a turbo system freshly installed and the turbo just had a screen attached to where you would see a pipe/tube that would end with an air filter or just where you would put an air filter on the turbo, eventually I am going to get a filter of some sort hooked up to it, but my main question is, is it ok for right now to drive until I get somthing like that hooked up to it, the screen does seem to do the job but I can not see it stopping certain things while driving... Anyone run there turbo with out a filter system hooked up to it?
Old Jun 11, 2006 | 08:42 PM
turbodcivic510's Avatar
10 months, no filter, no mesh...
no problems.
( in other words minds, water and really dusty crap, and youll be fine)
Old Jun 11, 2006 | 09:36 PM
Default Re: (g1_teg)
hmm ok well thats good news...
Old Jun 11, 2006 | 09:44 PM
D16SohcVtec's Avatar
Default Re: Running a turbo open with out a filter? (dangerranger21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangerranger21 &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully the title makes enough sense for you to get what I am talking about... I recently bought an Si with a turbo system freshly installed and the turbo just had a screen attached to where you would see a pipe/tube that would end with an air filter or just where you would put an air filter on the turbo, eventually I am going to get a filter of some sort hooked up to it, but my main question is, is it ok for right now to drive until I get somthing like that hooked up to it, the screen does seem to do the job but I can not see it stopping certain things while driving... Anyone run there turbo with out a filter system hooked up to it? </TD></TR></TABLE>
That screen mesh doesn't block dust and other crap small like that. For me, better safe then sorry. Put a K&N filter over it and call it a day.
Old Jun 11, 2006 | 09:46 PM
Default Re: Running a turbo open with out a filter? (D16SohcVtec)
Yah, but i will have to have some custom tube or somthing made becuz a filter wont fit the fan is in the way..
Old Jun 11, 2006 | 10:21 PM
qfast817's Avatar
what type of manifold are you running and what size of turbo? i know k&n makes custom filters
Old Jun 11, 2006 | 10:41 PM
Default Re: Running a turbo open with out a filter? (qfast817)
A drag manifold and T3T4 turbo
Old Jun 11, 2006 | 11:19 PM
RogueWorks's Avatar
running without a filter is just like running your NA car with only the CAI tube and no filter, only worse. Your gonna get all kinds of dirt, dust and crap into your motor.
Old Jun 11, 2006 | 11:45 PM
95GSRTT
Guest
Posts: n/a
try one of these, so you dont have to mock up a intake of sorts. Suppose to work really well and are cheap as **** right now.
http://store.summitracing.com/...10393
Old Jun 12, 2006 | 07:23 AM
Turbo_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g1_teg &raquo;</TD></TR><TR><TD CLASS="quote">10 months, no filter, no mesh...
no problems.
( in other words minds, water and really dusty crap, and youll be fine)</TD></TR></TABLE>
NOt proud of it, but i did the same
Old Jun 12, 2006 | 08:34 AM
vaporboy12's Avatar
Default Re: (MIKE JONES)
um i use to think it was ok until i had a 2 day old turbo eat a vacum line at the track not worth $1300 put something to cover it on thre
spec_v_kid's Avatar
Did the same thing for 2months, no problem yet... sux w. my top mount i cant run a filter...
Old Jun 12, 2006 | 10:21 AM
JDMs1eeper's Avatar
on my car I tested before and after on the dyno and only lost 1whp by puttin on a filter VS no filter. this was at 370whp
no filter sooner or later will kill the turbo I did it twice lol
Old Jun 12, 2006 | 11:10 AM
97turboteg's Avatar
Default Re: (vaporboy12)
running without any kinda filter is like running threw a field of bullets without a vest, why do it? do something dude, anything. If you suck something threw your turbo, its VERY possible to ruin your motor. Autozone got some **** that flexes, thats what i got with a filter at the end. you can move it around, it was like 20 bucks...
Old Jun 12, 2006 | 02:16 PM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangerranger21 &raquo;</TD></TR><TR><TD CLASS="quote">A drag manifold and T3T4 turbo</TD></TR></TABLE>
I'm running a Drag manifold with a stock Integra intake and a K&N for the Integ on my car. I pulled it off on the dyno and it didn't make anymore power with the open turbo.
I did have to get a FAL fan to make it fit.
Old Jun 12, 2006 | 07:10 PM
Default Re: Running a turbo open with out a filter? (FUCATYPR)
Wow, ok I think that the Autozone thing sounds good, some sort of flex piping with a filter put on the end... Is that Flex piping strong and not get out of adjustment?
Old Jun 12, 2006 | 08:02 PM
95GSRTT
Guest
Posts: n/a
Default Re: Running a turbo open with out a filter? (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">try one of these, so you dont have to mock up a intake of sorts. Suppose to work really well and are cheap as **** right now.
http://store.summitracing.com/...10393</TD></TR></TABLE>
Old Jun 12, 2006 | 08:20 PM
Tony the Tiger's Avatar
No filter on mine, 2 years, 28000 miles. Pulled the head apart to replace the LMA's + other work a while ago and I did an inspection along the way. No noticeable difference at all, no additional deposits, no scratches on walls or back of the valves, etc... Very slight chipping/dimples on the turbo compressor blades though, but not much of a concern.
Oil changed every 2500-2800 miles. Oil looks clean all the time. I also live in a very dusty area with construction on a daily basis. In fact, you'd get worse oil quality by running rich in comparison to running no filter.
I would like to have a filter, but sometimes it is not an option depending on manifold/turbo/full-size radiator w/ fans, etc....
Old Jun 13, 2006 | 06:38 AM
Default Re: Running a turbo open with out a filter? (Tony the Tiger)
Ok so, so far I am getting both sides here saying its ok without a filter becuase of their own experience and others saying you need a filter if you want your stuff to last...
Old Jun 13, 2006 | 06:49 AM
onemanlan's Avatar
Default Re: Running a turbo open with out a filter? (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">
I can understand the junkyard HMT crowd not running a filter though, because their entire setups will explode in a couple months anyways
Some HMT Setups have lasted longer than expensive setups here. However much of a merical they may be, some of them still manage to do it. It's not much different than here. Once you get better parts you're ready to upgrade. No problem with that.
Just think about it this way its about peace of mind, whether it helps or not. A $25-30 filter can save your entire investment, or ruin it too. If you put the filter directly on the compressor housing its liable to melt and get sucked in and destroy your turbo. It's happened before.
Old Jun 13, 2006 | 07:26 AM
Pnoyej6's Avatar
* B A N N E D *
Default Re: Running a turbo open with out a filter? (onemanlan)
it can fit a filter in there bro. I have full size fluidyne radiator and slim fans and i fit a filter along still have ac and ps
Old Jun 13, 2006 | 07:47 AM
Snafubmx234's Avatar
Default Re: Running a turbo open with out a filter? (pnoytegn707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">running without a filter is a great idea as long as you change your oil at least once a day.
I can't believe people still daily drive without an air filter! If a certain setup wouldn't allow me the use of an airfilter I would move on to the next setup, it's that important.
If you think about it it's like having a vacuum running at 150K RPM sucking in dirt and blowing it in your throttlebody....bearings LOVE dirt.</TD></TR></TABLE>
That was probably the most unintelligent comment on Honda-Tech.
I ran for 2 years without a filter, just a screen. I wouldn't suggest leaving it completely open, but don't think some K&N filter is going to save your motor from sucking in dirt/dust.
Old Jun 13, 2006 | 08:29 AM
StolenTeg's Avatar
Default Re: Running a turbo open with out a filter? (Snafubmx234)
i ran no filter for like 2 years also. but got a shitty filter now
Btw, filter suck turbo was ******* loud without it
Old Jun 13, 2006 | 08:31 AM
hmm wow 2 yrs and no problems!!
Old Jun 13, 2006 | 08:34 AM
97turboteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 &raquo;</TD></TR><TR><TD CLASS="quote">
I ran for 2 years without a filter, just a screen. I wouldn't suggest leaving it completely open, but don't think some K&N filter is going to save your motor from sucking in dirt/dust. </TD></TR></TABLE> dude your an idiot, just cause you didnt suck in dirt and Eff up a motor doesnt mean it wont happen. Why take the chance, spend the $20 bucks at autozone and not have to worry about spending whatever to get a new motor because somebody listened to you. But them guys did go a little overboard.
