NEED TO BORROW A WIDEBAND
i need to borrow a wideband to find out what is going on with my car. PLEASE http://images.honda-tech.com/set1//smile/emcrook.gif
Re: NEED TO BORROW A WIDEBAND (honda9369)
drive up to maine...$20 an hour and i'll help you diagnose
Re: NEED TO BORROW A WIDEBAND (Bailhatch)
shit i wish i still lived in vermont
anybody?
see i need to borrow a wideband cuz im flooding the engine and i want to put smaller inj in there and i want to make sure that im not running lean with the smaller inj
You haven't said anything to make me think you need a wideband to diagnose your problem. Care to elucidate on your problem, maybe we can advise? |
Re: (J. Davis)
oh. well i had put a walbro 255 hp in and its mad rich. i got a piece of shit b+m fpr and drilled a small hole in the stock fpr to get the fuel pressure down. i managed to get it down to 39psi and its still mad rich. i out new plugs in and idled for like 10 mins. and the plugs were coated black. im about to put smaller injs in so i can drive to jeff(boosted-hybrid) to get it tuned. i have a p-28 w/basemaps that run alittle rich. but im runnnin way to rich. only jeff (as far as the eastcoast) can tune this. 2000 civic y8 450 inj 255hp td04 19t,etc.
Re: (honda9369)
The super rich condition happened after the B&M FPR install?
I can tell you from personal experience that fuel maps change radically under boost based on compressor efficiency and turbine efficiency/AR, but the NA portion of the mappings stay more or less similar - enough to drive to a tuner on. What/who/why is your P28 basemap? I may have a buddy in Mechanicsburg, PA, I can impose on to burn another basemap for you, absolutely no promises on that as I can't speak for another man's free time, but I can ask. |
Re: (J. Davis)
the problem was b4 the b+m. im only 10 mins away from mech. sweet
Re: (honda9369)
the reason y i need 2 borrow a wb in i need to see what the a/f is and then check it agian with smaller inj to see if it is safe enough to drive to boosted for tuning
Re: (honda9369)
If you avoid boosting, closed loop takes care of part throttle mixtures, or at least close enough to get you to Jeff's. Smaller injectors + your FPR will probably get you where you need to be. Too rich or too lean and the car simply won't go, as you found out running it too rich. https://honda-tech.com/forums/images...es/emsmile.gif
Play with it a minute, let me know if you need a map to limp on. |
Re: (J. Davis)
well when i put the p28 in it was ok when i took it for a test drive but i was stupid and boosted it alittle and then it went down hill it backfired and i bearly made it back. do u think the base maps went crazy. i no it was stupid but my car was down for soo long i had to do it.
What program is on the chip? I mean Uberdata, Crome, Hondata etc...
Just D/L the program and make your own basemap. https://honda-tech.com/forums/images...es/emsmile.gif If you just need a chip burnt of your basemap it should be pretty easy to get done (if you dont have aburner). |
Re: (honda9369)
if you want I could make you a basemap and email it to you.
Re: (SOHC_MShue)
do you think if i took the walbro 255 high pressure pump out it would solve the fp problem?
Re: (honda9369)
At least point... since your setup has been doing Odd Things(tm)... If money for towing is relly an issue... I'd say try everything in your power to get it driveable at partial throttle so you can make it to Jeff's... Swap injectors, play with FPR, switch fuel pumps if you have to... If you still can't seem to get it driveable... Tow it as a last resort... https://honda-tech.com/forums/images...es/emdgust.gif
Re: (HRTuning)
hey james. well im working the next 4 days. the next thing im goin to do is swap the fuel pump. fpr already done. as u know i got it down to 39psi. which shouldnt give me problems,but it does. today i took the spark plug gap from .030 to .035 no diffference. i guess i can find some cheap prelude 310cc inj. but jeff wont be ready till the end of the month. since i cant borrow my dads truck i have to bum rides to work. hopefully i get some overtime so i can come up with some money. i sold the safc but wish i didnt so i could use it to cut fuel back.
Re: (honda9369)
Does he have any appointments before the end of the month? I may be able to set him up early so he can get you taken care of... Everything is in working order I was just waiting to demo it when he visits towards the end of the month...
Re: (HRTuning)
i believe that he wanted to wait till he saw u
Re: (honda9369)
Alright... I'll touch base with him tomorrow hopefully... and let you know what the deal is...
Re: (HRTuning)
i would apreciate any thing you could do. im desperate.
