Running Coolant
how hard is it to run coolant into my T3? I have a custom Turbo setup, where do you guys connect your plumbing?
Re: Running Coolant (whagkangmakulet)
i dont think anybody(well,except you) uses coolant flowing thru turbo unless they're drivin a saab or volvo or some other kind of stock turbo car
Re: Running Coolant (D-Man)
What I did was bypass the throttle body. So you have coolant that runs from the IAC to the throttle body(bypass throttle body) then into the turbo. The the outlet of the turbo to the coolant fitting under the vtec sylinoid(sp).
art |
Re: Running Coolant (Arturbo)
eyy Arturbo! Thanks.. one question for you? I have a T3 Turbo and i was wondering where did you get you plumbing that's connected on the turbo? http://images.zeroforum.com/smile/emsmile.gif
I purchased the water cooled bearing housing from Majectic turbo http://www.majesticturbo.com and I purchased all the plumming for it from http://www.anplumbing.com and http://www.bakerprecision.com
art |
| All times are GMT -8. The time now is 03:59 AM. |
