revving out of gear
Old Aug 14, 2003 | 01:53 AM
djnikko's Avatar
Default revving out of gear
when revving out of gear should u see boost on your boost gauge? or is it only in gear u build up boost? I cant see why it would be any dfferent i would of thought u see boost whatever... can anyone set me straight on this? do u see more boost when in gear? higher gears lower gears? thanks guys
Old Aug 14, 2003 | 02:14 AM
psileepR's Avatar
New User
Default Re: revving out of gear (djnikko)
unless its a tiny tiny turbo you wont see boost in neutral.
Boost is built with load on the engine. going up hill for example.
Old Aug 14, 2003 | 03:55 AM
djnikko's Avatar
Default Re: revving out of gear (psileepR)
i see, thanks mate. does the boost increase wuite steadily? the reason i ask is that i have no idea what psi the turbo is set up so i wanna be able to back off if i see it rising anywhere over 10psi ... i spose when u take your foot off the pedal the boost will increase spose its common sense just checking as ive never had experience with this before.
90Rexx
Aug 11, 2010 05:05 AM
Project X
Jul 17, 2008 08:38 PM
vangc6780
Aug 19, 2004 01:07 AM
eghatchproject
Feb 21, 2004 04:57 PM
Hoosier Daddy
Dec 25, 2003 04:32 PM
