rev hard ls kit
does anyone run this kit, what kind of #'s are you putting down and have u had any problems with it, the only other parts i was going to add to the kit was a hondata, blockgaurd, andtriple thick head gasket.
Why are you using a triple thick head gasket on an LS motor that is already 9.2:1? You may seriously experience some bad idle, and considering the block, it will just need that much more boost to make the same power.
Don't over think your setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Why are you using a triple thick head gasket on an LS motor that is already 9.2:1 </TD></TR></TABLE>
He is right
Ditch the thick head gasket and the block guard and spend that money on a good tune. Also you could use the SEARCH function of this site and it will give you back ALOT more info
He is right
