retune when switching to oem muffler?
Old Oct 11, 2008 | 11:24 PM
4dek's Avatar
Default retune when switching to oem muffler?
can anyone tell me if i need to have the car retuned if i switch back to my oem muffler which is obviuosly more restrictive than my turbo muffler? anyone pls help>>>>
Old Oct 12, 2008 | 01:20 AM
jDMJeRk's Avatar
absolutely.
Your exhaust back pressure is going to be horrible.
You should only have 1psi of back pressure per psi of boost being ran.
Do you have anything to measure back pressure with?
Old Oct 12, 2008 | 06:04 AM
2point2's Avatar
I tuned by car without the exhaust and when I bolted the (2.5" w/cat) exhaust back on there was a huge difference.
Old Oct 12, 2008 | 12:51 PM
4dek's Avatar
Default Re: (2point2)
i know there will be a huge difference in performance but im more concerned about detonation..any input anyone???
Old Oct 12, 2008 | 12:59 PM
jDMJeRk's Avatar
Default Re: (4dek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">i know there will be a huge difference in performance but im more concerned about detonation..any input anyone???</TD></TR></TABLE>
I'm curious in why you would think back pressure would cause dentation...
(In for answers too..)
Old Oct 12, 2008 | 07:15 PM
JShull's Avatar
I wouldn't think that it would cause detonation at all. Look at the guys using a cutout. It goes from open DP to full exhaust with the flick of a switch. If anything I would think the car is just gonna run rich and lose some power b/c of the restriction.
Old Oct 13, 2008 | 02:39 PM
4dek's Avatar
Default Re: (JShull)
i dont know if my tuner said less or more restrictive exhaust can make my car run lean or detonate. i just dont remember if he said more restrictive or less restrictive but i think he said more restrictive might cause it to run lean, but i think its the other way around or maybe i heaqrd wrong. so confused
Old Oct 13, 2008 | 04:54 PM
LSTEG96's Avatar
Default Re: (4dek)
1. Tune car on open DP.
2. add exhaust
3. watch AFRs go down. ( a ~little bit)
dtran002
Jul 5, 2012 06:17 PM
Jintegragsr97
Oct 5, 2009 12:40 PM
SadKorean34
25
Mar 9, 2009 01:39 AM
Nicaraguense13
15
Oct 26, 2006 01:52 PM
sirguy01
Welding / Fabrication
Jul 27, 2006 04:21 PM
