Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   resistor box (https://honda-tech.com/forums/forced-induction-16/resistor-box-1541210/)
zexifiedlude Feb 26, 2006 06:44 PM
resistor box
aight the section of the forum seems to be my last chance cause everyone in the prelude section are morons and cant answer my question or all the smart people are on vacations.
so what i really really need to know is how to wire a resistor box into my 5th gen prelude. my setup for my turbo project is an obd1 p72 ecu, dsm 450cc injectors, so what i pretty much need to know is how to wire in the resistor box, i kinda have an idea of how to wire in the obd1 clips so all i need to know about is the resistor box. when i searched i found this https://honda-tech.com/zerothread?id=517274 but i dont really understand what hes talkin about. so can someone help me out please. thanks
zexifiedlude Feb 26, 2006 08:22 PM
no one here either?.... wow honda-tech is really starting to dissapoint me
zexifiedlude Feb 27, 2006 07:38 AM
idiots
TIGboy Feb 27, 2006 09:29 AM
Re: resistor box (zexifiedlude)
im with ya, I need to know how to also. for my EG sedan
mrbigg9032 Feb 27, 2006 09:50 AM
Calling people idiots is really going to make them what to help u, u dumb shit!!!
ccivic Feb 27, 2006 10:08 AM
Re: (mrbigg9032)
It's very easy. This method will work for any Honda:
On each of your injector clips, you have a signal wire and a power wire. The signal wire will be different on all of the clips, but the power wire will be the same color on each clip. All you have to do is:
Cut all of the power wires, strip them and twist them together. Connect these wires to the one wire (usually black) that is different on the resistor box. Then the other four wires on the resistor box go to where you just cut the wires off leading to the injector clip. Order does not matter at all.
I Have an STD Feb 27, 2006 10:14 AM
Re: (ccivic)
search under the username T-RO. he's got a great write up
zexifiedlude Feb 27, 2006 05:37 PM
Re: (mrbigg9032)
ur the fuckin dumbshit, im not calling the people that help me idiots im calling people idiots that know what im talkin about and can tell me but wont take the time too. cause i am sure that more then a couple people on here have the resistor boxes wired in
zexifiedlude Feb 27, 2006 05:40 PM
Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">It's very easy. This method will work for any Honda:
Cut all of the power wires, strip them and twist them together. Connect these wires to the one wire (usually black) that is different on the resistor box. Then the other four wires on the resistor box go to where you just cut the wires off leading to the injector clip. Order does not matter at all.</TD></TR></TABLE>
thanks u sooo much!! ur kinda answer is exactly what i was looking for. i just have one question, i was thinking of doing it exactly how u said but i heard that u have to do it through the distribution block of the injectors. does that matter or now?
Mugencrxsir1 Feb 27, 2006 05:48 PM
https://honda-tech.com/zerothread?id=441107 https://honda-tech.com/forums/images/smilies/emthup.gif
Mugencrxsir1 Feb 27, 2006 05:50 PM
Re: resistor box (Mugencrxsir1)
https://honda-tech.com/zerothread?id=1263795 https://honda-tech.com/forums/images/smilies/emthup.gif
ccivic Feb 27, 2006 06:17 PM
Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">thanks u sooo much!! ur kinda answer is exactly what i was looking for. i just have one question, i was thinking of doing it exactly how u said but i heard that u have to do it through the distribution block of the injectors. does that matter or now?</TD></TR></TABLE>
No.. that doesn't matter.
mrbigg9032 Feb 28, 2006 03:46 AM
Try searching u asshole before u make a post that definalty has been answered already, your such a waste of time.
teal_dx Feb 28, 2006 06:59 AM
http://www.6thgearadvertising.com/mi...sistor_box.jpg
AbitAvenger Feb 28, 2006 08:24 AM
best diagram ever ^^
SL0WEGG Feb 28, 2006 10:27 AM
Re: (AbitAvenger)
wow...this has been covered, simple search would have found results. https://honda-tech.com/forums/images...es/emdgust.gif
T-RO Feb 28, 2006 12:18 PM
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">search under the username T-RO. he's got a great write up</TD></TR></TABLE>
Thanks, I appreciate that. https://honda-tech.com/forums/images/smilies/emthup.gif
Its not hard and like mentioned it has been covered numerous times.
1) Check for "continuity" which will tell you which wires at the dead end connector connect to your injector clips.
2) Unplug those wires
3) follow 1 of two paths:
Path A: Cut those wires and solder them together like mentioned above
Path B: Just unplug those wires and plug them into an OEM connector like in my writeup
Just remember to check for continuity because not all injector wires turn out to be in the same spot from car to car.
btotherizzle Feb 28, 2006 12:23 PM
Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">ur the fuckin dumbshit, im not calling the people that help me idiots im calling people idiots that know what im talkin about and can tell me but wont take the time too. cause i am sure that more then a couple people on here have the resistor boxes wired in</TD></TR></TABLE>
Your Mom is a Whore!
zexifiedlude Feb 28, 2006 04:07 PM
Re: (btotherizzle)
if u only lived close to me, i would show u what we do to people like u who say that kinda shit.
I Have an STD Feb 28, 2006 04:10 PM
Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">if u only lived close to me, i would show u what we do to people like u who say that kinda shit.</TD></TR></TABLE>
^e-thuggin at its finest. i give him two months before hes banned
b16ahybrid Feb 28, 2006 04:43 PM
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">^e-thuggin at its finest. i give him two months before hes banned</TD></TR></TABLE>I say 3.....$10 on it?... https://honda-tech.com/forums/images...es/emsmile.gif
.dave Feb 28, 2006 04:48 PM
Re: (zexifiedlude)
http://www.funtown.com/13octfun/pic.gif
<FONT SIZE="0">...for your mother of course.</FONT> https://honda-tech.com/forums/images...s/emsmilep.gif
Modified by daveG at 10:36 PM 2/28/2006
LSEGHATCH Feb 28, 2006 05:57 PM
Not tho thread jack but, do automatically have to wire in the resistor box or are there engine harnesses (oem) that you can purchase and already have the ready to go. If there are, do you need to up grade any of the components if running larger injectors than what that box was accountable for?
When I say engine harness I mean the whole thing, like out of a obd(?) honda.
btotherizzle Feb 28, 2006 08:36 PM
Re: (zexifiedlude)
I'm sorry I still love your Mom, it's just that we've been having a tough time lately. Guess What? You're a bitch! https://honda-tech.com/forums/images/smilies/emwink.gif
mrbigg9032 Mar 1, 2006 04:59 AM
Re: (btotherizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sorry I still love your Mom, it's just that we've been having a tough time lately. Guess What? You're a bitch! https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images...es/emsmile.gif
