Reliable Turbo DD? D16Z6
One option that I am considering in regards to my Civic is turboing it so that I may enjoy the car a bit more but one thing that always comes to mind is reliability. I do know what a turbo entails (turboing my RSX-S in 2 weeks. I have all the parts minus K-Pro) so I'm not a complete noob but I know near nothing about a D series. My goal is 200-250whp for a daily driven car that will maintain its reliability. So far from what I have gathered this is the set-up I am looking at but do want second opinions. If this option doesnt go through I may just swap the motor.
Motor: Vitara Pistons Eagle Rods ARP Headstuds Y8 Manifold Turbo (I'm still deciding so no need to comment on this unless something is waaay off): Log Manifold small T3/T4 turbo, possibly a T04E 38mm Wastegate the rest of the supporting bs lol Fuel: 450cc DSM Injectors Walbro hpfp? (is that needed?) Trans: I have NOOOO idea one this one I have no real "budget" persay but I dont want something priced ridiculously over the top either. My goal is to have a fresh motor that will last at least 150,000 miles (not exactly but you get where Im trying to go with that). Is that all that is needed motor-wise for a reliably boosted car from 200-250whp? Is cooling an issue with the tiny stock radiator? I shouldnt say money isnt an issue but I dont feel comfortable spending more than 2 grand for a turbo build when I bought the whole car for less than that. |
Re: Reliable Turbo DD? D16Z6
well if you dont want to spend more than 2 grand you have a lot of options turbo wise....
Walbro prob wont be needed if our stickin around 250hp |
Originally Posted by azandford
(Post 41984035)
looks like you have a decent motor? was it just built?
You could just get a decent turbo and tune it high, turn down the boost for everyday driving and turn it back up for a lil ol' tire squealin |
(Post 41984068)
bump id like to know this info. every built motor i see has 300+ whp but im not looking for that much
what is your question exactly?
from what i can read youre asking whether that would be reliable?
if so then yes totally if built and mapped properly . . . cooling depends on how you drive it, if you can afford a double thickness radiator i'd definately recommend it as lets be honest the standard ones are tiny. a company on one of the uk sites im a member of sells a kit for 250-300hp on a stock motor . . ' Hello, Following our B series thread here is the Dseries kit. The kit is aimed to give an alternative to the ebay kits, while costing more it offers far better value for money as it won't fail within a couple of months. Kit includes Race-Tech Ram style manifold, Race-Tech Downpipe Race-Tech Boost pipes and intercooler kit. Rebuilt TD04 turbo (320hp version is an extra £100) Normal version is good for 280bhp. Oil and water lines. The price for the first 5 kits will be £1200. Add £50 to make AC compatable. Normal price is £1450. We can also "downgrade" to a log style manifold which takes a further £100 off the price but the ram style does offer sizable gains. 2 year warranty on all parts, 3 years if fitted and tuned by us. The kit is ideal for standard engines and should do between 200-250hp at 11-17psi depending on tuning etc. Many other options available. ECU socketing and mapping, Injectors, fuel pumps, clutches etc contact for prices.' They have had no issues with that power even on a stock motor it seems, so a vitara'd built one should definately have no issues, just make sure its done properly and mapped up by someone who knows what they are doing. |
you can buy a trubo kit thats cheap and run it and blow a motor you can run an expensive turbo kit and blow the motor
depends on how built your motor is and how much you beat on it and a little bit of luck go with forged internals and some arp headstuds |
Originally Posted by 95civhb
(Post 42005178)
Originally Posted by Gtr Chris
(Post 42005299)
(Post 42005496)
As for your setup, the stock internal D series is good for 220-240whp reliably. Since your goal falls within that range, you dont need to build it, but it wouldnt hurt. If you're not looking to ever make more power (and don't lie to yourself, you will want more eventually) then you can leave it stock.
As for the turbo setup, i think you have a decent start. Your goals are realistic and would be very streetable. I'm not sure what your exact question was, but if you need suggestions for your setup, we can give you that. My first suggestion would be to look at a smaller turbo. Personally, i would get a T3 Super 60 for your goals. It would be much more streetable than a larger T3/T04e XXtrim and will give you the same peak power potential
(Post 41984035)
What he said..... A stock d series will handle your goal easily with a good tune. I've got a 93 Si with a bone stock D16 (ARP studs though) with a Greddy kit and a old school Hondata that I've been running for over 10 years and I've had no problems with the exception of lifting the head at 18+ psi in the winter cold. (Damn small turbo and internal wastegate) D's have a problem with lifting head at high boost. I put in the ARP's and haven't looked back. I don't drive the car daily anymore but I do drive it at least once a week and I often beat the piss out of it. My set up for the last 10 years has been: Stock D16Z6 with ARP head studs Bolt on Greddy turbo kit with Greddy FMI and old school Greddy BOV 255 lph Walboro and 440 RC injectors Old school Hondata 2B system with stock MAP sensor Old school Greddy electronic boost controler Greddy 2.5" PE exhaust ACT clutch (forgot which one) Made 185 WHP and 177 WTQ at 8psi on a very conservative tune in '01. I asked the tuner to be conservative with the tune as it was my only mode of transportation at the time. The last 6 or 7 years I've been running 1 gal of C16 to a tank of 93 and pushing 15 psi which is the max for the little TD04. Car has never been re-tuned since and from the ass dyno, and what I have seen from others with similar set ups, I'm guessing somewhere between 230-245 WHP. The only thing I would like to add is traction bars, better mounts, (stock sucks), an LSD, and drag radials. I would love to re-tune the car before I finally get with the times and go B series. LOL! Alot of people hate the Greddy kits but they are reliable, spool up super quick, and can make a decent, fun street car. Almost like a factory turbo Honda. Good luck with your build. |
^^ to the two posts above me, those are really good numbers that can be held with a stock d16z6. i just rmember reading that you dont want to push it above 200whp but maybe im confusing it with another d series motor. i know my friend doesnt want to up his boost and hit 170whp on his d16y8 since all it has are headstuds.
Originally Posted by imbest123
(Post 42035838)
Originally Posted by 1Jackleg
(Post 42035967)
The Z6 and Y8 will easily hit 200-250 whp with the correct tuning and fuel. There have been a few who have gone over 300 whp with the D in stock trim. I think you might be pushing a D15B at 200 whp though.
Okay reading this thread made me think about boosting my 98 hx I think it has the y5. Does anyone know how much this motor can handle stock with no mods to the motor at all. With like a small t25. I'm thinking of going the sleeper route with a small dsm side mount
(Post 42004141)
https://cimg0.ibsrv.net/gimg/honda-t...5f74a84bd8.jpg with a turbo. 1993 Del Sol Si. https://cimg2.ibsrv.net/gimg/honda-t...b8fa2310ed.jpg https://cimg3.ibsrv.net/gimg/honda-t...8b207f2624.jpg She has a LONG way to go. Im just tired of tying to nake her look gokd when what I really want is for her to go fast. Lol |
Originally Posted by SolTrain92
(Post 50636317)
Sorry if this is the wrong post... But how much do you think you can get out of that engine max? I have a D16z6 Soh vtech 1.6 ML. I'm conserdering buying that same engine to put on a stand to build it up to be setup
https://cimg0.ibsrv.net/gimg/honda-t...5f74a84bd8.jpg with a turbo. 1993 Del Sol Si. https://cimg2.ibsrv.net/gimg/honda-t...b8fa2310ed.jpg https://cimg3.ibsrv.net/gimg/honda-t...8b207f2624.jpg She has a LONG way to go. Im just tired of tying to nake her look gokd when what I really want is for her to go fast. Lol Crap. Don't drink and ask questions on websites. You use the wrong terminology. Lol. L not ML. |
(Post 50636318)
And the 'drinking' A) Check the dates, why the f*ck are you bumping a 5 year old thread? B) Read the faqs, this is a really simple question you could answer for yourself, and I know you must know how to use the search feature otherwise you wouldn't have been able to find this thread in the first place We need a bot for this smh fam |
Bumping 5 year old threads doesn't get anyone anywhere.
If you have specific questions then make a new thread. If you want to see other turbo D series setups and power levels there's an entire thread devoted to that in this forum. PS "VTECH" is a phone company LOCKED |
