Re-tuned my car
Old Jan 8, 2006 | 04:25 PM
2000turbosi's Avatar
Default Re-tuned my car
my set up is as follows:
b18c1 with arias 9:1 pistons
titan rods
ls crank
stock b16a head
t3/t40e 57trim .63ar
precision fmic 600hp
inline pro mani
turbosmart wg
turbosmart boost controller
walbro 255 fuel pump
550cc injectors
hondata s100 with boost
tuned by inline pro for 1bar 14.5lbs...
Old setup can be found on this link...
*to see the old dyno graph, scroll down a bit...
https://honda-tech.com/zerothread?id=903837
Looking for suggestions...I realize with stock sleeves and stock head 400whp is going to be my max hp, which is fine...Im also looking to make the most hp possible with my current setup...I thought Inline Pro did a good job tunning my car (conservative), but they also recommended possibly in the future a SC61 compared to my garrett t3/t40e...they said i could gain 20-40 whp...which if i sold my turbo and then bought a new SC61 would only be $300...just trying to see what you guys think, i believe both turbos spool up at about the same time, etc...My car currently is very fun to drive, so Im debating with my self a bit, should I get the SC61 or stick with my current turbo?...thanks for any help
Modified by 2000turbosi at 1:52 AM 1/9/2006
Modified by 2000turbosi at 1:55 AM 1/9/2006
Old Jan 8, 2006 | 04:27 PM
King Tut33's Avatar
Default Re: Re-tuned my car (2000turbosi)
You wanna make that picture any smaller?
Old Jan 8, 2006 | 04:28 PM
Sorry for the delay...I had to resize the pic...thanks again for any input/help...
Modified by 2000turbosi at 1:53 AM 1/9/2006
Old Jan 8, 2006 | 05:09 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Re-tuned my car (King Tut33)
Nice powerband...
You don't need to waste $300 for a new turbo. Bump it up to 1.4 bar
Old Jan 8, 2006 | 05:13 PM
Default Re: Re-tuned my car (NightRider-gsR)
thanks for the repilies....keep them coming...i was really happy with the tune....1.4 bar might be too much for my motor to handle...
Old Jan 8, 2006 | 05:17 PM
Dartanian's Avatar
I like your torque curve. Nice and flat. Good numbers.
You could probably get 20-40 hp just from some upgraded cams.
Old Jan 8, 2006 | 06:10 PM
thanks...keep the suggestions coming...
Old Jan 8, 2006 | 06:58 PM
Kelly.'s Avatar
I've quit using this account
what are you injectors at (duty cycle?)
i say turn it up.
im running 25 psi on stock sleeves with the same turbo (.48 turbine) on a sohc
Old Jan 8, 2006 | 07:43 PM
mtber's Avatar
You should be able to make a little more power out of the setup with more boost.
Another intake manifold (if your running a stock gsr) along with ctr cams would help a lot.
If your goals are 400whp I would look into larger injectors.
Old Jan 9, 2006 | 01:37 AM
Thanks for the help...Ive thought about type r cams, intake manifold, tb for a while....right now i just have the stock b16a setup...Everybody seems to be saying that my turbo is fine...just turn up the boost...I just dont want to blow my motor again...One time is good enough for me...just curious with the same set up how much more hp do you guys think my car would make with the SC61...thanks again for the suggestions
Old Jan 9, 2006 | 04:23 AM
ATYPR's Avatar
Get bigger injectors, ITR/CTR cams, and turn the boost up.
Old Jan 9, 2006 | 04:37 AM
Turbocivic94's Avatar
Stock sleeves are not your problem. I would upgrade injectors and turn up the boost. I'be seen plenty of 400whp stock sleeve setups.
Old Jan 9, 2006 | 06:14 AM
EVIL Hx Coupe's Avatar
Default Re: Re-tuned my car (Turbocivic94)
Stock sleeves arent really holding you back now. If anything I would be worried about the valve train parts giving up on you.
I've always been paranoid about valves bending or dropping. Also your injectors wont be good for alot more power, so an injector upgrade would be good too.
Dont change the turbo yet. There's other things you can do to your motor to make it stronger and then you can just turn up the boost and make the power you want to make.
Old Jan 9, 2006 | 06:31 AM
Default Re: Re-tuned my car (EVIL Hx Coupe)
Alright thanks for the help...i was thinking of upgrading my valvetrain...Ive always been in contact with inline pro...the owner always told me the b16a valvetrain is efficient (and strong enough) up to about 500hp...looks like ill stick with my turbo and maybe work on some other things...
thanks again
Old Jan 9, 2006 | 07:15 AM
gsrboy171
Guest
Posts: n/a
stand alone management
what is your duty cycle of your injectors and what kind of fuel pump?
Old Jan 9, 2006 | 07:19 AM
Default Re: (gsrboy171)
Walboro 255 fuel pump...Hondata (which im extremely satisfied with)....and Im sorry to say but I dont know what my duty cycle is...I forgot to ask the tuner...
this info is already in the above Set up Info, all except for the duty cycle information... thanks again
Old Jan 9, 2006 | 07:52 AM
m R g S r's Avatar
i dunno doesnt torque seem weak for ls vtec makin 319whp?1
Old Jan 9, 2006 | 09:54 AM
Default Re: Re-tuned my car (m R g S r)
I think the torque seems about right...for b16a head, gsr block Ls crank...the numbers seem about right...anybody else with similar set up can chime in with their .02....
Old Jan 9, 2006 | 12:33 PM
Old Jan 9, 2006 | 12:52 PM
TurboCoop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbosi &raquo;</TD></TR><TR><TD CLASS="quote">I think the torque seems about right...for b16a head, gsr block Ls crank...the numbers seem about right...anybody else with similar set up can chime in with their .02....</TD></TR></TABLE>
B18B1 block-B18C5 head, 8.5:1 SRP pistons, Eagle rods, block guard, Golden Eagle head studs, TOGA rod bearings, OEM honda headgasket, MSD ingition w/ blaster coil, custom log turbo maniold, Garret T3/T04E .48 exh./.60 turbine, full 3" downpipe and exhaust, Tial 38mm, Edelbrock Victor X IM, LS TB, Apexi BOV, Greddy Profec B Spec II @12psi, LS tranny, Exedy 3 puck clutch, DSM 450's, Walbro 255, tuned with Hondata....
We had the injectors almost maxed out on a few pulls, that was the only weak point. The turbo is kind of small too, I am going back in a month or 2 with 750's and the same turbo with the ball bearing center section and my tuner said I would easily make 400whp.
Old Jan 9, 2006 | 04:14 PM
Default Re: Re-tuned my car (TurboCoop)
Thanks for all the replies...everybody has been most helpful...any other comments are welcome as well...
Old Jan 9, 2006 | 07:13 PM
yee SERIOUS's Avatar
hmm. i would've thought you'd be making a little bit more power. but everything looks very nice. what size IC pipes are you running and what size downpipe?
Old Jan 10, 2006 | 12:54 AM
Default Re: (undercoverdc2)
Inline pro downpipe...2.5inches- 3inch exhaust...no cats....charge pipes are the drag upgraded pipes....2.5inches except the uppipe...which goes from like 2inches to 2.5inches
Old Jan 11, 2006 | 06:32 AM
Default Re: (2000turbosi)
bump...
Old Jan 11, 2006 | 08:23 AM
4rc-fed's Avatar
You seemed concerned with how much boost you are running. More boost won't break anything.... too much HP will. If you feel safe up to 400whp then just crank the boost and get closer. ITR cams and a intake manifold would also help you get there.... Best of luck
