RC Injector Clip Install
Old Nov 6, 2005 | 08:01 AM
19t EX coupe's Avatar
Default RC Injector Clip Install
Ok, do the RC 310cc injectors that come with the Greddy 19T kit splice into the same wires as the stock injectors? Basically, if you were to hold the two injector clips side by side, would the left wire on the stock one be the same as the left wire on the RC clips? I need to know if I splice left wire to left wire, or right wire to left wire or what....
I assume it would be left to left wire, but I want to be sure so I don't damage my ECU or something crazy like that.
thanks in advance
Old Nov 6, 2005 | 08:56 AM
ccivic's Avatar
Default Re: RC Injector Clip Install (19t EX coupe)
You should notice that your injector wires coming from the harness all have one wire that is the same on all four (yellow/black). This wire is your power wire, the other wire is the signal from the ECU. Find out which wire is power and which is signal on the RC plug and you're good to go.
Old Nov 6, 2005 | 09:02 AM
EVIL Hx Coupe's Avatar
Default Re: RC Injector Clip Install (ccivic)
Polarity doesnt matter with injectors. Just put the car clip next to the RC and swap the wires.
Make sure you get them sordered/heatshrinked. Splicing and electrical tape wont make very good contact and tape probably will even come off with time.
Old Nov 6, 2005 | 09:31 AM
Default Re: RC Injector Clip Install (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Polarity doesnt matter with injectors. Just put the car clip next to the RC and swap the wires.
Make sure you get them sordered/heatshrinked. Splicing and electrical tape wont make very good contact and tape probably will even come off with time.</TD></TR></TABLE>
that was my plan, was to splice and tape. I guess I'll hold off on installing them until I can get someone to solder them for me.
I've heard that stock injectors can still handle 8psi? If so, there's no rush on getting these installed
YoungKadafi
Mar 21, 2007 08:12 AM
littletriad
Sep 25, 2006 09:01 AM
19t EX coupe
Nov 6, 2005 08:49 AM
Bimmerman
May 12, 2005 08:26 AM
green_GSR
Mar 5, 2003 04:02 PM
