RC 550cc Injectors fitment problem
Old Sep 2, 2005 | 03:53 PM
RNPoo7's Avatar
Default RC 550cc Injectors fitment problem
Hey guys, im' trying to install my new injectors on my B16 intake manifold).
They are RC injectors 550cc, but I can't get them to fit.
Are they universal??
Old Sep 2, 2005 | 03:57 PM
dohcdelsol93's Avatar
Default Re: RC 550cc Injectors fitment problem (RNPoo7)
The part number on the injector is sl9-550. I tried searching but could not get a definitive answer. The RC injectors do not fit as far down into the manifold as far as the oem injectors. Am I just Supposed to install the O-ring and let them sit only a 1/4 inch deep in the IM?
Modified by dohcdelsol93 at 5:58 PM 9/2/2005
Old Sep 2, 2005 | 04:59 PM
Default Re: RC 550cc Injectors fitment problem (dohcdelsol93)
bump
Old Sep 2, 2005 | 05:33 PM
RNPoo7's Avatar
hump
Old Sep 2, 2005 | 05:42 PM
Default Re: (RNPoo7)
hahaha.... u said hump. Bump for me, trying to finish this injector install before it rains
Geauxkart's Avatar
Look in the intake maniofld - I had to remove some oem spacers in the manifold. I bet yours has them too. Look in the manifold injector ports for a black plastic spacer. Hope it helps.
Old Sep 2, 2005 | 06:00 PM
King Tut33's Avatar
Default Re: (Geauxkart)
They don't sit the same way as oem. Put the o rings in the intake manifold and put the injectors into the fuel rail. Then tighten down the fuel rail and the injectors should seal up kind of on top of the gaskets. As long as the fuel rail is tight and the injectors seal up your fine. Just remember to put the gaskets in the manifold instead of on the injectors.
Old Sep 2, 2005 | 06:35 PM
Default Re: (King Tut33)
the small plastic spacers that you guys are talking about (the ones that sit between the injector seal and the IM) have already been removed. I have temporairly taken the RC injector spacers and placed them directly into the IM. Then taken the wider(much wider) d-series injector seals and place them onto the RC injecotrs. This took up for the almost 1/8 gap I was getting with placing the RC injector in the IM with their provided injecotr seals. It seems a bit tight, I cannot move the injectors back and forth like the stock one did but I took care not to over torque them.
I tried to pair the d-series injector seals with the small plastic bushings (bored out to fit the RC's) but this still felt a bit uncomfortably loose to me. If anyone else has any other suggestions pleas give me a shout.
BTW pete, if you could stop by sometime this weekend to take some pics so I can post them up that would be hella sweet.
Old Sep 2, 2005 | 07:22 PM
RNPoo7's Avatar
sweet man. Hey Josh, i think i'm gonna go to the Clemson game tomorrow. I'll stop by after that.
But there's a chance that I can't go, i forgot to get my ticket lol, so i might head up to G vagas earlier.
Old Sep 2, 2005 | 07:39 PM
dude, you need to get me some clemson tickets, oh and a widespread panic ticket
Old Sep 2, 2005 | 07:49 PM
RNPoo7's Avatar
Default Re: (dohcdelsol93)
yah i need to find you a football ticket, i'll see what I can do. Can you make it tomorrow if i find a ticket since your car is down and all.
Also, i think they are sold out of the football game ticket. I'll see
Widespread panic concet info:
Date: 10/11/2005
Time: 8:00 pm
Description: Tigerpaw Productions is proud to present Widespread Panic on Tuesday October 11.
There is no student discount available for this show.
Doors open at 7 pm.
Old Sep 2, 2005 | 07:50 PM
scott92hatch's Avatar
I just installed rc 550s like 3 months ago, and i had the same prob for like 3 days i tryed to get them to fit and sit like oem ones do then finaly i got out the dremal and shaved a little bit of the out side of the o ring and a little bit of the inside of the oring and they slide right in and sat low in there like oem
any ways hope this helps
Old Sep 2, 2005 | 10:52 PM
dunkd's Avatar
put some oil on the orings, it will help them slip in easier... maybes thats the prob?
Old Sep 3, 2005 | 09:28 AM
Default Re: (dunkd)
the problem is not with the o-rings. The problem is that the lower portion of the injector, the part of the injector that fits into the IM is larger than the holes it's supposed to fit into. The plastic rings have been removed and the rc seals are being used but it still didn't work/look right.
Old Sep 3, 2005 | 09:39 PM
dunkd's Avatar
is there a part $ on the injector? call RC and make sure its designed to be used with a honda and something GM. ive heard of that before...
Old Sep 3, 2005 | 10:10 PM
RNPoo7's Avatar
Are they not universal?
Old Sep 4, 2005 | 04:53 AM
O16581724 5 2 5's Avatar
You've been told how to install them, they do not seat like factory, you put the O ring in the intake manifold and set the injectors on top, there's a small lip on the bottom of the injectors that seal them. The rings do not slide onto the injectors.
Go install them like you've been told.
Old Sep 4, 2005 | 10:30 AM
Default Re: (O16581724 5 2 5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">You've been told how to install them, they do not seat like factory, you put the O ring in the intake manifold and set the injectors on top, there's a small lip on the bottom of the injectors that seal them. The rings do not slide onto the injectors.
Go install them like you've been told.</TD></TR></TABLE>
gosh, I'll do it when I get a chance
Old Sep 4, 2005 | 10:58 AM
nsxmatt's Avatar
Exactly, you tighten down the fuel rail little by little till they just start to bulge the spacer slightly and they will not leak.
Old Sep 4, 2005 | 11:34 AM
King Tut33's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, you tighten down the fuel rail little by little till they just start to bulge the spacer slightly and they will not leak. </TD></TR></TABLE>
Exactly. I thought I had explained it pretty well in my first post but I guess not.
b20beast83
Dec 16, 2008 11:08 AM
S13 slide
Dec 23, 2005 09:19 PM
