radiator problem....
i have an aluminum radiator and the nipple that hooks up to the overflow hose came off , ive tried jb weld numberous times and it doesnt hold for that long , can i soldier it???? i was gonna try that and see if it works . what are your thoughts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Who makes it? No warranty?
Maybe try drilling out the location where it goes and tapping it 1/4" NPT, then using a pipe to hose barb fitting.</TD></TR></TABLE>
Very smart idea. Why dont you find ur old rad. and use it while the alum. is being fixed?
JB won't hold it since they use a ferrous metal base. The aluminum expands twice as much when hot and the JB weld just flakes off. You can probably use silver solder since it melts at a slightly higher temp than lead solder. I don't think that the radiator would get hot enough the melt the solder anyways. It's worth a try!
Osek206
Aug 14, 2005 02:00 PM
