Question on going obd0-obd1 with the harness
Old Apr 8, 2003 | 07:21 PM
qqqq
Guest
Posts: n/a
Default Question on going obd0-obd1 with the harness
Do i just plug the harness on and get a p28 ecu or do i have to change other stuff? also i want to do it so i can get a aem ems and run it but will it work if i do that?
Old Apr 8, 2003 | 07:29 PM
paulzy's Avatar
Default Re: Question on going obd0-obd1 with the harness (babyboib16)
if I remember...you need an obd1 distributor and a resistor pack.
Old Apr 8, 2003 | 07:30 PM
tony1's Avatar
Default Re: Question on going obd0-obd1 with the harness (Paul_Vang)
you need an obd 1 dist., and a 4 wire o2 sensor. If you keep the low impedence injectors and the resistor then you'll be fine.
Old Apr 8, 2003 | 07:36 PM
qqqq
Guest
Posts: n/a
Default Re: Question on going obd0-obd1 with the harness (tony1)
so just any dist from a obd1 gsr and where do i get the 4 wire 02 sensor off of?
Old Apr 8, 2003 | 07:38 PM
Flamenco-T's Avatar
all OBD1 and up O2 sensor should be 4 wires, pos, neg and 2 heater..
stan
Old Apr 8, 2003 | 07:53 PM
qqqq
Guest
Posts: n/a
Default Re: Question on going obd0-obd1 with the harness (Flamenco-T)
is the o2 sensor frome a obd1 car?
boosted97civic
Mar 19, 2007 04:32 PM
SPL Dan
Jul 27, 2005 01:02 PM
civtegra_hybrid
Sep 14, 2004 01:15 AM
Another B16
Jul 7, 2004 06:17 AM
