Question About Wideband o2 w/o controller....
Old Mar 15, 2006 | 07:25 AM
turbotime's Avatar
Default Question About Wideband o2 w/o controller....
So I am looking into wideband o2 units, specifically the m300, and i have a question.
I have an apexi full auto turbotimer, and it features o2 sensor voltage and a/f readout. This can be calibrated for any o2 sensor range (narrow by default). So technically could i just get teh wideband o2 sensor itself and NOT the controller and use the TT to monitor the a/f's?
Do i need the controller for the wideband to work? Is there any use for the controller other than monitoring the wideband output?
Old Mar 15, 2006 | 08:10 AM
raene's Avatar
Default Re: Question About Wideband o2 w/o controller.... (turbotime)
Read up a little bit on how widebands work and you'll see why that's a ridiculous thought... although we all thought it a few times before we did our homework LSU4 sensor
Old Mar 15, 2006 | 08:57 AM
turbotime's Avatar
so it basically needs to interface with the controller in order for the voltage to be properly read? or it needs the controller to properly function at all?
Old Mar 15, 2006 | 09:09 AM
raene's Avatar
Default Re: (turbotime)
It cannot read at all without the controller. The controller drives the pump, and the entire accuracy of the wideband depends on the pump. You can have a controller without a display, however!
Old Mar 15, 2006 | 09:12 AM
turbotime's Avatar
cool thats what i want then a controller w/o display.. are they cheaper ?
Old Mar 15, 2006 | 09:42 AM
Importordomestic's Avatar
http://www.homemadeturbo.com/f...498.0
smo0th
Jan 24, 2009 10:34 AM
eatbieodie2
Jun 7, 2005 02:23 AM
Turbo'dMex-A-Keen
Jun 24, 2003 07:18 PM
