problems with my oil feed line/fitting
Old Jan 10, 2006 | 04:00 PM
Outkast95LS's Avatar
Default problems with my oil feed line/fitting
Im having problems with the T fitting. I cant seem to get this part screwed all the way in.
Here's what it looks like right now..
Old Jan 10, 2006 | 04:05 PM
sohc_turd's Avatar
Default Re: problems with my oil feed line/fitting (Outkast95LS)
Do both peices have matching threads? (BST/NPT)
By the way... please don't use brass T's or fittings off the block. You'll be sorry.
Old Jan 10, 2006 | 04:17 PM
notanotherSC61's Avatar
Default Re: problems with my oil feed line/fitting (sohc_turd)
This is because it is flared. It will tighten more and more as you torque on it. Do yourself a favor use a remote oil distribution or a sandwich adapter, that will break eventually with the vibration and rotation of the motor.
Old Jan 10, 2006 | 06:48 PM
mike93eh
Guest
Posts: n/a
my greddy kit came witha brass T fitting and has been working great for a year now.
Old Jan 10, 2006 | 07:03 PM
King Tut33's Avatar
Default Re: (mike93eh)
Yeah as long as you aren't hanging a heavy oil pressure sending unit off the brass T fiting it should be fine. Don't let them scare you. I, however, would also recommend the Golden Eagle oil sandwich plate in the future.
Old Jan 10, 2006 | 07:24 PM
aznballer's Avatar
yea nuthin wrong with a brass fitting had mine on fro 3 yrs now
Old Jan 10, 2006 | 10:13 PM
stealthmode62's Avatar
Default Re: (aznballer)
You'll find that alot of fittings don't thread all the way into another fitting. The flare on the male thread won't exactly be the same as the female fitting. As long as you assemble everything in a responsible manner, you won't have a problem with what you have.
On another note, it'll be impossible to install it all assembled anyway. Start with the first fitting going into the block and go from there.
Old Jan 10, 2006 | 10:28 PM
Default Re: (stealthmode62)
thanks guys, i put some teflon tape and made it nice and snug. Hopefully it'll hold up. Still need to get my oil pan tapped, then i'll see if there's any leaks
VitaD16
Mar 13, 2014 11:28 PM
tuhboek
Jun 21, 2010 05:51 AM
sampol999
Sep 3, 2006 01:09 PM
hondaeg8
May 23, 2006 11:53 AM
integranator
Apr 24, 2003 09:42 PM
