Problems with JRSC...HELP!!
Old Jun 4, 2004 | 01:21 PM
Ekay Jay's Avatar
Default Problems with JRSC...HELP!!
I have a jackson racing supercharger on a b15b7. It runs great, awsome throttle response. But for some reason it redlines at 3500rpm. Im running stock 90 si computer with a DOHC ZC wiring harness, i am alosu running the DOHC ZC injectors. I put a meter to my grounds and they are going bazerk. Can anyone please help me?
Old Jun 4, 2004 | 03:29 PM
Ekay Jay's Avatar
Default Re: Problems with JRSC...HELP!! (Bo0sT3d_CrX)
Old Jun 4, 2004 | 06:59 PM
Muckman's Avatar
Moderator in Chief
Those nutty grounds...
What does it do when it hits 3500rpm? Any CELs?
Old Jun 4, 2004 | 07:58 PM
Ekay Jay's Avatar
Default Re: Problems with JRSC...HELP!! (Muckman)
It freaking goes to 3500rpm and dosnt go any further. cels?
Old Jun 4, 2004 | 08:24 PM
Muckman's Avatar
Moderator in Chief
Check Engine Lights
Does it get to 3500 and spit and sputter? make any finny noises or does it feel like the normal rev limiter?
Old Jun 4, 2004 | 09:08 PM
Ekay Jay's Avatar
yes there is check engine light. Its throwing codes 4 and 9 i believe. It will go to 3500rpm and then bounce off of it. And no it does not seem normal, i should be going to 6400rpm.
Old Jun 5, 2004 | 12:51 PM
Ekay Jay's Avatar
anyone?
Old Jun 5, 2004 | 03:42 PM
CL9WestCoastin's Avatar
CEL 4 and 9 or 4 and 8. if it is 4 and 8 , then the plug for the TPS and the MAP sensors are switched.
Old Jun 5, 2004 | 06:11 PM
Muckman's Avatar
Moderator in Chief
Default Re: Problems with JRSC...HELP!! (loketran)
lol that will def do it! Common mistake tho as the plugs are interchangeable.
My next suggestion was going to be check the MAP sensor if it has the right vacuum source.
Old Jun 5, 2004 | 08:42 PM
Pengo's Avatar
always fix those CELs first before you attempt to diagnose anything else.
Old Jun 6, 2004 | 04:58 PM
Ekay Jay's Avatar
Default Re: Problems with JRSC...HELP!! (Pengo)
Naw man there is no way u can mix them up cuz tha wires arnt long enough ta reach.
salvador96
Jul 23, 2014 08:50 PM
~sp33~
12
Mar 12, 2011 08:20 PM
recorod54
Jul 18, 2007 07:33 AM
roadrunner1
Mar 7, 2006 10:33 AM
schtozo
Nov 25, 2002 06:39 PM
