Pressure plate OEM
HI,
I need to know Whitch of all OEM D serie Pressure plate is the stiffness???
Thanks a lot.
Modified by civic1990si at 6:31 AM 2/9/2004
Thanks a lot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">I'll tell you tomorrow or the next.</TD></TR></TABLE>
Laugh out ******* loud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic1990si »</TD></TR><TR><TD CLASS="quote">
You didn't get to English class much did you?
I am pretty sure they are all the same.
SOHC's have no ******* torque to hold onto.
ok,
but i'm not boosting 15 psi.
For now i'm boosting 5 psi and maybe 7 or 8 psi so i think an oem pressure plate can idle that.
What do you think??
What do you think??
I believe most of the street clutches, Clutchnet stage 2 for example which is recommended for mild boost and hot NA cars, use a stock pressure plate with an upgraded disk. I know I had some luck with stock PP and ACT 4 puck on my LS, if D-series PP is at all similar I would recommend something like that for a mild boost street setup.
cbmprelude
May 23, 2006 02:48 PM
