Preferred Vacuum Choices...?
Old Apr 12, 2006 | 06:57 AM
infulleffect's Avatar
Default Preferred Vacuum Choices...?
Okay, after doing a search and finding very little, I coming to this forum to see what the preferred spots are for "T-ing" off of to operate the BOV, boost guage, etc.
I realize that the FPR has its own special line that goes un-touched
So that leaves me with the following options:
1) the fitting on the lower part of the throttle body (Use to connect to the valve cover breather)
2) the lower left side of the intake manifold (that use to connect to the valve cover breather)
3) the vacuum line the runs from the upper part of the intake manifold down to a plastic valve in the center of the lower part of th inake manifold.
4) I guess the brake booster could be and option, but I am trying to avoid using that line so I won't have to step the vacuum line down to 1/4in.
Basically what connections have worked best and have been the most successful to use.
Thank you
Old Apr 12, 2006 | 07:18 AM
turbotime's Avatar
brake booster + GE vauum manifold FTW
do once. do it right. done.
Or u can be cheap and T off pretty much every vac source for your engine and then have a rats nest of vac wires.
choose ur poison
Old Apr 12, 2006 | 07:41 AM
Default Re: (turbotime)
I did see the Golden Eagle vacuum manifold, but it looked huge and I wasn't sure where to "tuck it away". Any pics with this unit installed available?
Old Apr 12, 2006 | 07:50 AM
yee SERIOUS's Avatar
i had everything T'd off my FPR line for about 9months. i had my bov, wg, fmu, and boost gauge all off the fpr. LOL!
when i put in my golden eagle vac manifold and t'd it off the brake booster, i only hooked up the bov and wg to it. all that was left on my fpr was the boost gauge and fmu for a week (i ditched the fmu a week later and got tuned). my butt dyno told me that everything was WAYYYY more responsive with the vac manifold off the brake booster. felt tons better
if u get a golden eagle manifold and the fittings, the fittings come with a T to tap the brake booster. that's what i used, just needed 5inches of a 3/8ID hose. no clamps it's pretty damn tight on there. lol
Old Apr 12, 2006 | 07:51 AM
turbotime's Avatar
^ yup
the manifold is tiny, it can easily be tucked, but im gonna show mine off- its anodized baby!
Old Apr 12, 2006 | 07:56 AM
Race Egr's Avatar
Or just get a jd edlebrock intake manifold there is alot of extra fittings right in the underneath of it for vacuam sources'
Old Apr 12, 2006 | 07:59 AM
Soccerking3000's Avatar
Default Re: (NAPIER)
or you could just drill and tap the stock manifold and add some barbed fittings on the back for 6 bucks
Old Apr 12, 2006 | 08:15 AM
Default Re: (Soccerking3000)
Believe it or not I considered the last option, except I am tired of removing parts...I don't want to take off anymore parts
I'll wait to see the GE box, that may be the best option...any recomendation on where to purchase it for a reasonable price?
Old Apr 12, 2006 | 08:19 AM
Default Re: (infulleffect)
camp1320.com
Old Apr 12, 2006 | 08:29 AM
turbotime's Avatar
http://www.goldeneaglemfg.com
Old Apr 12, 2006 | 08:38 AM
I found it on the lightening, camp, and streetrays site for $36 shipped...now I just need to see a pic of it installed to make sure it is what I am looking for
Old Apr 12, 2006 | 09:00 AM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
Or u can be cheap and T off pretty much every vac source for your engine and then have a rats nest of vac wires.</TD></TR></TABLE>
i dont see how its a rats nest. you need a boost gauge and bov vacuum lines. i used my fpr for boost gauge and brake booster for bov. Your way is cleaner ill admit but i wouldnt say a rats nest.
Old Apr 12, 2006 | 09:01 AM
Default Re: (Macan00n)
but then there is the wastegate, and if you have an electronic boost controller it gets worse and worse
Old Apr 12, 2006 | 09:04 AM
just search for vac manifold. there's a few good pics. hahaha. i searched about a month ago for some. ladysman (i think) has a nice setup one, i'll try to get pics of mine today or tomorrow.
i got my vac manifold from boostfed.com
Old Apr 12, 2006 | 09:07 AM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Macan00n &raquo;</TD></TR><TR><TD CLASS="quote">i dont see how its a rats nest. you need a boost gauge and bov vacuum lines. i used my fpr for boost gauge and brake booster for bov. Your way is cleaner ill admit but i wouldnt say a rats nest.</TD></TR></TABLE>
yeha i mean u can set it up tobe clean but in the end all ur difference items are seeing slightly diff vacuum even tho its a closed system, although the manifold is nice cause it cleans up the bay, the main purpose is so all ur vac-peripherals reference the same point, and the brake booster is one of the biggest vac sources in the engine plenty of vacuum to go around
Old Apr 12, 2006 | 09:46 AM
Obviously there must not be a problem with this, but I have to ask...since you are using the vacuum line to the brake booster...is there anymore noticable brake fade?
Old Apr 12, 2006 | 10:05 AM
not with mine
Old Apr 12, 2006 | 10:46 AM
dpetro1's Avatar
here's a pic that shows the whole setup installed.
another alternative is to order all the parts from mcmaster or something similar. thats what i did. the block itself is much smaller and you can order a block with as many or as little ports as you want. it was a bit cheaper that way, but no golden eagle bling.
here's a close up of my setup. i was only using 2 ports at the time cause the install wasnt complete. but you get the idea. its hiding nicely under my strut bar.
here is a pic I sourced while searching...is there anyother places this thing has been stashed?
Old Apr 12, 2006 | 10:49 AM
dpetro1's Avatar
i think right on the firewall is your best bet. but i think ive seen someone with a vac distribution box somewhere near the drivers shock tower. wasnt golden eagle though.
Old Apr 12, 2006 | 10:50 AM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">brake booster + GE vauum manifold FTW
do once. do it right. done.</TD></TR></TABLE>
i got my GE vac manifold at a local shop.
for small things like that, i try to support the local guys
i use mine for
bov
3 bar map
boost guage
and 2 for my boost controller
good lcuk
Old Apr 12, 2006 | 10:58 AM
Default Re: (Kelly.)
mine is actually behind the firewall inside the windshield thing with just the ports in the firewall coming out it looks pretty tight i'll get some pics soon
edit: THIS IS NOT MY CAR ITS PANDAHATCH's but the vaccum setup is similar to mine
Old Apr 12, 2006 | 11:33 AM
dpetro1's Avatar
ITBs are sexy. clean *** car.
Old Apr 13, 2006 | 04:44 PM
Default Re: (dpetro1)
Looks like I'm going with this set up...
http://hondamarketplace.com/zerothread?id=1547160
Old Apr 13, 2006 | 04:52 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">or you could just drill and tap the stock manifold and add some barbed fittings on the back for 6 bucks</TD></TR></TABLE>
Absolute best way IMO. I always add ports when I pull an IM off a turbo car. Just did a WRX one yesterday...
The best part is you can put them in hidden places, nearby the part that needs the line rather than having a big octopus on your firewall
Modified by Bailhatch at 11:10 PM 4/13/2006
