precision turbo injectors
Old May 18, 2008 | 01:18 PM
beaterman's Avatar
Default precision turbo injectors
Well I just ordered a set of precision turbo injectors for my obd1 turboed ls/vtec. I got the 525cc ones that are made for honda's. My mechanic said that the injectors do not fit and the plugs wont even mate up. Now I have contacted the company and they have told me these are the correct injectors. Has anyone had to do any modifications to these injectors to make them fit? The company I bought them from said I may have to sand down the plugs to make them fit. Anyone had to do this?
Old May 18, 2008 | 01:31 PM
SpoolnG2's Avatar
Default Re: precision turbo injectors (beaterman)
I thought they were specifically made for hondas? Where did you purchase them from?
Old May 18, 2008 | 01:34 PM
beaterman's Avatar
Default Re: precision turbo injectors (SpoolnG2)
LSD Motorsports here on Honda-tech. Im not having a problem with them or precision but for some reason they just dont want to fit the plugs.
Old May 18, 2008 | 01:50 PM
StolenTeg's Avatar
IS your plug OBD2, it need OBD1 plug
Old May 18, 2008 | 01:58 PM
beaterman's Avatar
It should be an obd1 plug. the car is a 92 civic si with an ls/vtec engine. the plugs are grey.
Old May 18, 2008 | 07:37 PM
SpoolnG2's Avatar
you may have to notch out a small piece of the clip out on the inside of it. Its the part on the back that is a straight line coming down. I cut that out with a razor and I dont have any problems. Thats on an obd1 harness.
Old May 18, 2008 | 08:30 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">you may have to notch out a small piece of the clip out on the inside of it. Its the part on the back that is a straight line coming down. I cut that out with a razor and I dont have any problems. Thats on an obd1 harness. </TD></TR></TABLE>
you beat me to it...
Old May 19, 2008 | 01:22 AM
beaterman's Avatar
thanks for the replies. I have been told about the "sanding" of the plugs to make them fit. anyone else have any problems?
Old May 19, 2008 | 07:49 PM
TheShodan's Avatar
Moderator
Yep. Those use EV1 plugs (it's not necessarily OBD based), that should fit those no problem. Some even have FORD housings on it. They don't go by OBD necessarily
Modified by TheShodan at 7:44 PM 5/25/2008
Old May 20, 2008 | 07:34 AM
acrocat's Avatar
ya you need to use a lil blad and cut off the lil notch on the inside of the injector plug... then they will plug right up... i'm using the precision 780 injectors in my car with no problems.
Old May 20, 2008 | 07:56 AM
Lewy. Dee Ayy's Avatar
Default Re: (acrocat)
once u cut that lil tab off will oem injectors plug back in?
Old May 20, 2008 | 08:03 AM
acrocat's Avatar
yes because you are modifying the injector side not the engine harness side
Old May 20, 2008 | 03:03 PM
beaterman's Avatar
ok thanks for all the help.
Old May 25, 2008 | 04:35 PM
BoostMulishaB16's Avatar
i have 1000cc precisions in my obd1 95 hatch you have to shave down the single stub in the injector then they will fit right in.GL
Old May 26, 2008 | 10:25 AM
RC000E's Avatar
Default Re: (beaterman)
Your "mechanic" couldn't figure this out? Watch out
Old May 27, 2008 | 01:23 PM
beaterman's Avatar
Default Re: (RC000E)
yes he didnt want to start hacking into the plugs since they are supposed to be direct fits.
Old May 27, 2008 | 02:09 PM
gettin it's Avatar
Are your injectors the slim style or the fat ones?
Old May 27, 2008 | 06:02 PM
beaterman's Avatar
Default Re: (gettin it)
not sure these are the first set i have bought. the guy from precision turbo said they are the correct ones.
Old May 28, 2008 | 01:58 AM
gettin it's Avatar
Yeah, i just talked to them yesterday also. They told me my 650's will fit. I don't know why the say honda style. What size do you have? Do you have to run a resistor box?
Old May 28, 2008 | 03:38 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Your "mechanic" couldn't figure this out? Watch out </TD></TR></TABLE>
X 2 on that ! what kinda "mechanic" doesnt notice something so simple ? let me guess, they went to uti, and now they are "mechanic" LMAO
Old May 28, 2008 | 03:18 PM
beaterman's Avatar
Default Re: (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">yes he didnt want to start hacking into the plugs since they are supposed to be direct fits. </TD></TR></TABLE>
just in case you cant read. this is a good mechanic that works at acura. just cause someone doesnt want to go hacking into someone elses parts doesnt make them bad. would you want a mechanic to start hacking on parts that you bought just to make them fit if they were the wrong part.... i think not. so dont speak before you know and dont bash people that care about others ****.
Old May 28, 2008 | 03:59 PM
mike93eh2's Avatar
if he was a real performance mechanic he would have known you have to razor out that piece inside the plugs for precision injectors. that is in no way "hacking" it harms nothing and is a simple 2 second job. now if he was a half *** mechanic he would have also noticed by comparing the two that all he had to do was cut down that little stub in the plug.
and LMAO at most dealership mechanics. almost all of them are NOT real mechanics. they just go by what books and computers tell them to do. they are basically robots.
DaveF's Avatar
what makes him a good mechanic ? apparently his eyes arent working very well or he may have noticed this small differance.....................you dont know what he does on a daily basis ? cutting a small plasic tab is hardly "hacking ****"
Old May 28, 2008 | 05:22 PM
StolenTeg's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">if he was a real performance mechanic he would have known you have to razor out that piece inside the plugs for precision injectors. that is in no way "hacking" it harms nothing and is a simple 2 second job. now if he was a half *** mechanic he would have also noticed by comparing the two that all he had to do was cut down that little stub in the plug.
and LMAO at most dealership mechanics. almost all of them are NOT real mechanics. they just go by what books and computers tell them to do. they are basically robots.</TD></TR></TABLE>
So you're saying anyone who work at a dealership have no knowledge of car? what are workshop manual for?
To fix car with the least effort? or maybe you know it all and fix everything with a snap of a finger.
Must be nice
If a tech is doesn't have common knowledge of performance part then of course they would think it a wrong part. When it said to be a direct fit, it should plug right in.
Old May 29, 2008 | 03:44 AM
DaveF's Avatar
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">
blah blah blah blah, just trying to make myself feel better.
crying shame i tell ya....
do you also need your eyes checked ?
maybe we should all go back to school, so we can learn how to "read signs"
zerovandez
May 28, 2014 09:44 PM
B_Swapped93
Mar 30, 2013 10:59 AM
roachsboosted16
Dec 2, 2007 01:24 PM
PhatBoy5015
May 29, 2006 06:38 AM
