Post your boosted Bseries internals wishlist
Old Apr 12, 2004 | 07:32 PM
crazy eyez killa
Guest
Posts: n/a
Default Post your boosted Bseries internals wishlist
What are the best internal setups for boosted Bseries motors? As far as pistons, blockguard, etc,
And affordable stuff too
Old Apr 12, 2004 | 07:49 PM
G
sh!t happens.
Default Re: Post your boosted Bseries internals wishlist (Vortech99Si)
im gettin
manly rods (fullrace)
cp pistions
ls/vtec setup
beason sleeves
and portflow head
with type r cams..etc
thats my wish list... SAVING for it....
Old Apr 12, 2004 | 08:04 PM
*Boostwerks*'s Avatar
Gold plated everything...j/k
If I were to get more than what I currently have it would be...
Payn tech piston/bearing coatings
Thats all.
Old Apr 12, 2004 | 10:09 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: (Bryson)
hell ya... do you think someone could make a custom gold plated B16 block for me?
Old Apr 12, 2004 | 10:39 PM
Joseph Davis's Avatar
Default Re: (Vortech99Si)
If you're building a street car, stock.
Old Apr 12, 2004 | 11:01 PM
mitsuman's Avatar
Default Re: (J. Davis)
all i would really want would be some 9.5:1 CP pistons, crower rods, and bearings. cheap build
Old Apr 12, 2004 | 11:19 PM
jeremy.'s Avatar
Default Re: (mitsuman)
i want some cp pistons and cunningham rods!
Old Apr 12, 2004 | 11:50 PM
quik sol's Avatar
lsvtec conversion
benson sleeved block
full-race rods
arias 84mm pistons to make it a 2.0L
and mase to do my hondata s200 w/ all options....tuning
Old Apr 13, 2004 | 05:00 AM
m R g S r's Avatar
Default Re: (quik sol)
My setup:
GE sleeved 85mm b16
CP pistons
Pauter rods
Stock b16 crank
OEM oil pump
All new OEM seals
ACL main bearings
Fluidamper harmonic balancer
Stock GSR head
Venom intake manifold
ARP headstuds
GE headgasket
Old Apr 13, 2004 | 05:34 AM
TurboBumblBee's Avatar
Default Re: (m R g S r)
My Setup is
AEBS 84mm t-sleeves
CP 9:1 pistions
Eagle Rods
ARP headstuds
Cometic 84mm HG
OEM water, oil pump, bearings
GSR stock crank
Just want to get the head built and ill be done, GSR tranny already has quiffe lsd and was rebuilt last year!
Old Apr 13, 2004 | 05:52 AM
g2turbo's Avatar
Default Re: (Boostfedb18c1)
My setup:
Benson sleeves, 81mm c5 shorblock
CP pistons 9.8:1
Manley Rods/Full Race
Stock headgasket, waterpump etc.
Pro Drive gears
Old Apr 13, 2004 | 06:17 AM
Sound Streamin''s Avatar
my plans are simple. crower rods, some type of 9.1 pistons, and get my crank balanced.
Old Apr 13, 2004 | 06:31 AM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">My setup:
GE sleeved 85mm b16
CP pistons
Pauter rods
Stock b16 crank
OEM oil pump
All new OEM seals
ACL main bearings
Stock GSR head
ARP headstuds
GE headgasket</TD></TR></TABLE>
I've got a stock block GSR about to be boosted right now.
I may end up getting
ARP headbolts
Eagle Rods
CP Pistons
that would be my build.
quite possibly a thicker headgasket if I didn't get the Pistons. Just so I could drop the compression a bit.
fairly cheap route, but would be effective
Old Apr 13, 2004 | 07:18 AM
TurboJesse
Guest
Posts: n/a
Default Re: (patdemps)
OEM B16a Block
OEM P30 pistons
OEM rods
ARP Head studs
Inline Pro 2mm Gasket
Old Apr 13, 2004 | 04:22 PM
crazy eyez killa
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">If you're building a street car, stock.</TD></TR></TABLE>
the problem is i have leaking rings and poor compression in my cylinders so its definitely time for a rebuild... take it to 8k rpm and black smoke pours out my exhaust...
BennyS
45
Apr 19, 2016 10:27 PM
93turbo16
Aug 17, 2006 07:10 PM
93turbo16
Aug 17, 2006 07:09 PM
boostin4door
10
Feb 25, 2005 02:02 PM
h22acivicman
Sep 30, 2004 02:00 PM
