is it possible to do an afc hack with factory injectors? if so how?
Old Sep 15, 2002 | 06:06 PM
B17aTrbo's Avatar
New User
Default is it possible to do an afc hack with factory injectors? if so how?
i don't have the 440cc injectors yet but can i do the hack with the factory injectors? thanks...1
Old Sep 15, 2002 | 06:52 PM
turbosol's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (B17aTURBO)
No!!!
Old Sep 15, 2002 | 06:54 PM
speedymon's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (turbosol)
Hahahhaha are you crazy?
Old Sep 15, 2002 | 06:58 PM
bretx0r's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (speedymon)
WHY would u want to. -40% on stock injectors oh wait IM NOT GETTING VERY MUCH FUEL
Old Sep 15, 2002 | 07:17 PM
98civicEX's Avatar
of coursre you can w/ factory injecotrs. DSM 450cc w/ resistor box
Old Sep 15, 2002 | 07:38 PM
wickedxboi's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (98civicEX)
no, the factory injectors are 2 small.
Old Sep 15, 2002 | 07:52 PM
CzanSOHC's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (wickedxboi)
go ahead and give it a try.......................let us know the results
Old Sep 15, 2002 | 10:04 PM
filetofit
Guest
Posts: n/a
Yup, you take your VAFC and set it to 100% across the board and you don't run any more than 1 psi of boost.
Old Sep 15, 2002 | 11:25 PM
ion_four's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (filetofit)
Harsh guys, harsh.
Do a search to read how it works. You're actually reducing the fuel supplied when you use the afc hack, but you aren't running lean because the injectors are huge compared to stock. if you didn't have the larger injectors you'd just be running lean as ****.
Old Sep 16, 2002 | 05:52 AM
B17aTrbo's Avatar
New User
Default Re: is it possible to do an afc hack with factory injectors? if so how? (ion_four)
i meant with instead of -40 at -5...i have it at -5 across the board as it is now...
Old Sep 16, 2002 | 06:00 AM
speedymon's Avatar
The hack works buy reducing the map signal enough so that when you boost it doesn't trip a CEL. The 40/35% cut happens to be a happy medium for reducing the MAP signal AND cutting enough fuel from 390-450cc injector to idle and boost a Honda nicely. Cutting the fuel 40% will allow you to boost on your stock map, but you engine will blow because your have no fuel.
[Modified by speedymon, 10:01 AM 9/16/2002]
Old Sep 16, 2002 | 06:07 AM
senpai's Avatar
I don't think someone is reading the posts on the AFC hack/trick ....
Old Sep 16, 2002 | 07:42 AM
speedymon's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (maztur)
I don't think so either...
Old Sep 16, 2002 | 09:32 AM
fastludeh22's Avatar
sure it will work perfectly, all you have to do is get a fpr and turn the psi to 180, no biggie. i dont know why the even make bigger injectors, just turn up the psi
Old Sep 16, 2002 | 12:02 PM
speedymon's Avatar
Default Re: is it possible to do an afc hack with factory injectors? if so how? (93ludevtec)
Blown O rings are kewl!
Old Sep 16, 2002 | 08:12 PM
B17aTrbo's Avatar
New User
now i finally see how it works...thanks
rnbguy
May 12, 2007 09:05 AM
BOOSTEDC4
Jan 28, 2006 05:52 AM
slammedcivicsi
Sep 7, 2004 09:00 PM
KevronsEG
Aug 13, 2002 07:34 PM
ZERO COOL
Jul 15, 2002 05:36 PM
