positive manifold pressure
Old Sep 27, 2002 | 11:07 AM
1SpoolnH's Avatar
Default positive manifold pressure
can you go into positive manifold pressure. i have a99 civic sohc with the greddy turbo kit. when i go down to cali i go into positive manifold pressure on my vafc controller. i don't have the greddy black box hooked up and also what does that do.
Old Sep 27, 2002 | 11:18 AM
DC2R714's Avatar
Default Re: positive manifold pressure (1SpoolnH)
You can't go into positive manifold pressure because you do not have a turbo ecu; therefore your map sensor will show your ecu a voltage that it does not understand sending it into limp mode, which sucks ***. You have to find away to trick your map sensor into only reading vacuum. Look up on search for afc hack or smc map limiter or you can use a missing link or check valves.
followthadollar
May 2, 2010 09:04 PM
EJ8 GSR-T
Feb 19, 2007 09:11 PM
jedsus
Jul 10, 2006 05:47 PM
jedsus
Jul 10, 2006 12:04 PM
