please help me out
Old Dec 18, 2002 | 08:24 PM
4ghatch's Avatar
Default please help me out
i have just installed a zex nitrous system in my stock 91 civic dx and all i have added were the zex plugs to the motor. I was wondering if a 55 shot would be safe for it the way it is at 129,xxx miles? thanks for your time
Old Dec 18, 2002 | 08:32 PM
PrecisionH23a's Avatar
Default Re: please help me out (4ghatch)
i would recommend doing a cylinder leak down test to check your engine's compression. you can get away with a 55 shot and zex plugs. if you want to be on the safe side i would look into running an ignition system and retarding your timing.
Old Dec 18, 2002 | 08:53 PM
4ghatch's Avatar
Default Re: please help me out (GudeH23a)
hey thanks for the help i'm going to check compression on my car this weekend. What should it be within? and also i want to retard the distributor 2 degress. Am i right?
Old Dec 18, 2002 | 09:25 PM
Yes, a good rule of thumb is retard the timing 2 degrees for every 50 shot. Im not sure what compression your car is, but the readings should be 10-15% within each other i believe. do a search for archived topics "compression"
dpw41285
Feb 18, 2005 07:56 PM
Arch-Angel
Mar 5, 2003 09:31 AM
Turbo Lude SH
Nov 13, 2002 03:41 PM
Rah Rah
Jul 24, 2002 11:39 AM
